Results 1 to 10 of 10
Thread: Another Cooling System Question
    Feb 2015
    Raleigh,NC
    1997 Z3 Roadster 2.8
    I’ve had my Z3 for three years now and I am at last going to redo the cooling system and have a few questions. Yes, I’ve read innumerable posts but I’m dense!
    I have a ’97, M52, 2.8, 5 speed. I’ve seen a lot of posts about the two plastic coolant pipes/tubes and thought I must have those too. Went to realoem.com and put in my VIN and got this
    I don’t see the two pipes.
    My questions are:
    Is this drawing correct that my M52 does not have these two pipes?
    I do see a heater return pipe (6). Is this plastic and therefore should be replaced?
    Does this drawing accurately reflect my '97 M52 cooling system? I want to be sure all the old coolant hoses are replaced.
    Thank you for your help!
    Jan 2015
    Timaru, New Zealand
    Two Z3 Roadsters
    Yes you have the correct diagram
    Yes No 6 is the hard plastic tube and its the only hard plastic tube you have.
    The two hard plastic tubes relate to the M52TU and M54 engines.
    1999 2.8L Z3 Roadster,
    2000 3.0L Z3 Roadster,
    Aug 2015
    Denver, CO
    1999 Z3M, 1999 2.8 Coupe
    Every time I hear "cooling pipes" I cringe. I did them on an M52TU, but I think the M52 is far easier to remove the intake. You should have no problems.
    Nathan in Denver
    Feb 2015
    Raleigh,NC
    Thanks for the responses guys. When I posted this I had no idea an answer would come from half way around the world!
    On the M52 they are metal, ive never replaced them, even have a brand new pipe from when I ordered everything I saw in the diagram lol
    PRICE CUT on ALL FABRICS
    Feb 2015
    Raleigh,NC
    Quote Originally Posted by BimmerBreaker View Post
    That's great. Thank You!
    Oct 2016
    West Central Indiana, USA
    2000 BMW Z3 2.3
    Quote Originally Posted by Muzz258 View Post
    Sorry to resurect, but can someone post the part numbers for these plastic tubes?
    I am trying to piece together all of the part numbers I need to refresh the entire cooling system on my 2000 Z3. (April '99 build) I am realling struggling to find reputable sources to get a correct list of part numbers for the 52TU engine.
    Every spring I say I am going to get this job done, and every spring I get frustrated trying to find all the parts I need and give up. It really has to get done this year.
    Aug 2015
    Denver, CO
    Quote Originally Posted by rhitee93 View Post
    Check post #15:
    https://www.bimmerforums.com/forum/s...r-water-pipes!
    I strongly recommend replacing the heater hoses as well.
    Nathan in Denver
    Oct 2016
    2000 BMW Z3 2.3
    Thanks Natahn, the plan is to replace all the bits other than the heater core. It's been a challenge for me to identify everything. The "kits" that are available don't have all the parts, and I suspect none of them are right for the TU engine.
    So far I have the following:
    Heater Inlet Pipe #11531705210
    Water Pipe #11537502525
    3 Heater hoses #s 64218377673, 64218376608, and 64218362777
    There are the obvious components: radiator, upper and lower radiator hoses, expansion tank, thermostat housing and water pump. Are there any other not so obvious parts that are easy to miss? I really don't want to get the car apart and find out I didn't order something.
    Aug 2015
    Denver, CO
    It wouldn't hurt to toss in a new temp sensor. 3621433076
    There is also a hose that runs from the expansion tank to the front of one of the heater pipes, but it was backordered when I did my system so I never replaced it. It's held up just fine and you can reach both ends with everything in place if you ever need to replace it.
    Hose part#:
    11537505831
    Also, the grommet on my water valve was missing, so ordered one of those up too. The heater hoses basically keep it in place, but was nice to have that mounted properly.
    Oh, and don't forget to buy coolant (you'd be surprised).
    Nathan in Denver
  1. Another cooling system question
    By pjo33us in forum 1991 - 1999 (E36)
    Last Post: 03-14-2014, 12:14 AM
  2. Another cooling system question...
    By Draw415 in forum 1999 - 2006 (E46)
    Last Post: 09-29-2010, 10:29 AM
  3. Another cooling system question, about gaskets
    By Ewok Fetus in forum 1992 - 1999 M3 (E36)
    Last Post: 05-07-2010, 08:26 PM
  4. yet another cooling system question. this one a little different
    By turb0charged in forum 1991 - 1999 (E36)
    Last Post: 06-22-2006, 12:42 AM
  5. Another cooling system question
    By TCM3 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 02-21-2004, 12:43 PM
