Results 1 to 9 of 9
    Jul 2017
    bucuresti
    bmw x5
    Bmw x5 e70 2011 oil leak from oil filtre housing
    3.0d xdrive my car leak oil from oil filtre housing i went to a car service and they recommend me to change the all filtre oil housing not the gasket...beacause if they change only the gasket after will leak even more oil its that true? what is the correct solution?
    The correct repair is to remove the housing, replace the gaskets, and reinstall the housing. Then clean up any leaked oil. There is absolutely no need to replace the complete housing.
    Jan 2016
    Montreal/Cape Coral
    2012 X6 35i
    What is it with BMW and oil filter housing gaskets? Seems that regardless of the motor, the gaskets on these housing tend to leak after a while...
    2007 FJ Cruiser (best vehicle to date)
    2012 X6 35i Sport
    2013 ML350 BT
    2019 4Runner
    And the valve cover gaskets, and the oil pan gaskets. It's just a feature of BMW's.
    Jan 2016
    Montreal/Cape Coral
    2012 X6 35i
    "Feature" LOL. You make it sound like a free option ....
    2012 X6 35i Sport
    2013 ML350 BT
    2019 4Runner
    Mar 2019
    Hoschton, GA
    2008 BMW X5, 2018 BMW X3
    Replaced my filter housing gaskets a couple weeks ago. Seems to have fixed the leak. I had two BMW shops note the leak when I had the car in for other service, neither one quoted changing the actual housing.
    Jan 2016
    Montreal/Cape Coral
    2012 X6 35i
    As an aside, the housings leaked on both our X6 and our ML350 BT within 6 months of each other
    2012 X6 35i Sport
    2013 ML350 BT
    2019 4Runner
    Fairfield, Connecticut
    '98 540i '01 540i 13 E70
    Quote Originally Posted by White94RX View Post
    Old thread but is it an easy FYI?
    Also what is the oem part number for a ‘13 3.0 e70?
    Seems there’s 2?
    Thanks in advance!
    Can someone confirm on an oil filter housing gasket leak, do I need both gaskets or just one of number 4 or 5?
    TIA!
  1. E70 BMW X5 E70 Rear Seat DVD Entertainment System OEM Kit New
    By jtharmon in forum Car Audio & Electronics
    Last Post: 01-17-2018, 05:50 PM
  2. Repairing Oil Leak from Oil Filter Housing Gasket and Oil Cooler Gasket - 2011 535i
    By check raiser in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 01-14-2017, 05:11 PM
  3. E70 Share BMW X5 E70 Car accessory stainless steel scuff plate door sill plate LED light
    By mycareye in forum Exterior Lighting & Body Parts
    Last Post: 06-22-2015, 10:48 AM
  4. Bmw E30 318is oil leak after oil change
    By Bimmer91E30 in forum 1983 - 1991 (E30)
    Last Post: 12-28-2010, 01:31 AM
  5. oil leak after oil change
    By connorb850 in forum 1991 - 1999 (E36)
    Last Post: 05-17-2007, 11:46 AM
