Results 1 to 5 of 5
Thread: Need help with diagnosis
    Sep 2018
    Noblesville Indiana
    Bmw 335i
    My 335i recently hit a pothole and cracked a rim and busted a tire, I had an aftermarket warranty on it and took it to a shop to get replaced. And it wasnt having this issue before i took it in, but when I got the car back, something immediately felt off and I noticed the rear wheels aren’t making proper contact with the road. The right rear (the one that got replaced) is touching the ground at a weird angle almost like its actually hitting the ground first. And you can tell by looking at it from the back that the right pass side of the car is sitting higher because of that wheel. Also on level ground theres a bigger gap in the pass rear wheel well now. I’ve had it aligned, looked at it myself, had it taken to 3 different euro shops and none can find the issue. Its annoying because the car cant put its power down at all and the handling’s so bad because of it, its a danger to drive, especially in the snow and it being rear wheel drive already. I need suggestions on what would even cause this. Never experienced something like this and id hate to start guessing suspension components blindly.
    Jan 2016
    Ca
    2001 525it
    Have one of those shops drive with you, it's hard to believe that the alignment would not have picked something up id
    Jan 2016
    Ca
    2001 525it
    Any way before my key board went wacko, it's hard to believe that the alignment print did not not show a problem. I mean it was a pretty hard hit to do that damage. How good are these folks at there alignments. You could also get it back up in the air and start checking with a tape measure.
    Peoria, AZ
    03 zhp, 97 e36m3, 04 zhp
    Make sure the spring on that side is seated correctly.
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    My Cars: Bmw 335i
    pls add model and built year to your profile. I assume E90, moved to E90 forum
  1. Need help w/ diagnosis
    By kickservebt in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 09-05-2007, 04:25 PM
  2. Car won't start - need help with diagnosis!
    By mrnvgtr in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 05-17-2007, 06:40 PM
  3. Need Help w/Diagnosis
    By ck1995 in forum 1991 - 1999 (E36)
    Last Post: 04-18-2007, 06:22 PM
  4. Need help with diagnosis
    By sdean4816 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 09-28-2005, 02:12 PM
  5. Need help with diagnosis
    By AmberLeigh in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 04-22-2004, 04:23 PM
