Forced to sell due to new living space restrictions.
2004 BMW 330I ZHP 4 door 6 speed with full Alcantara interior
132k miles
Clean title
Always garaged
I have owned and babied this car for the last 8 years. I am a certified technician and have personally done all maintenance on this car. Everything was done with OEM or OE quality parts.
The car was never tracked, never raced, never abused. All maintenance was done preventatively. All stock in exception to a few aesthetic modifications.
There are a few aesthetic "modifications" that can easily be put back to stock upon request.
Black and white BMW badges,HID foglights, Smoked front corner lights and red/smoked/red tailights.
The car has Powerflex urethane front control arm bushings and Powerflex rear trailing arm bushings. Currently the car is lowered on H&R lowering springs, but as mentioned, I have the factory ZHP springs as well.
At around 105k I did spark plugs, valve cover gasket,oil filter housing gasket, dual Vanos seals, fuel filter,cooling system including T-stat and waterpump, both belts, Transmission fluid.
Oil has always been replaced with Pentosin Super performance III. Fuel has always been Chevron 91 octane.
Brakes are Akebono ceramic with Zimmerman rotors and have about 85% life all around. Tires are Continental DW with about 90% all around.
The car runs perfect. No hesitation, no lag, no issues. Does not have the common 4k rpm power dip that some ZHPs have.
The car needs absolutely no work or maintenance just a good home and someone who will continue to appreciate it as much as I have.
Asking $10,500. Located in SF, CA. If interested, please PM me your phone number.
Too bad you are far away from North Florida / South Georgia.
Still available?
Mods, please delete/close thread.
