Results 1 to 8 of 8
Thread: rough at home alignment prior to driving to shop?
    Jan 2019
    houston
    2017 F150, 97 M3
    I am doing a complete suspension overhaul on my m3...all bushings, new lower rear control arms, coil overs, etc. and all the specs are going to be way off when I'm done. How should I go about getting it so its ok to just drive 15 miles to a shop? Do I need to get my coil overs set to the height I want them prior to an alignment or can I do that later without affecting the alignment?
    Aug 2008
    North Potomac, MD
    2011 E90 328i
    Height should be set before alignment, and unless you added something, the only thing you can set is toe, which you can do with a carpenter's ruler. See youtube.
    MD
    99 M3 / 95 325i
    I can usually eyeball it surprisingly well. But the better answer is to use a set of toe plates to roughly set the toe before you get going.
    -Chris
    Nov 2010
    Whidbey Island, WA
    1998 Techno M3 Coupe
    Can you trailer it in? Are you setting the preload?
    I had mine brought in to the suspension shop on a flatbed tow truck.
    I left the preload bushings bolts loose and had the suspension shop torque everything under load (much easier on a lift).
    Feb 2009
    Mills River, NC
    95 M3 coupe, 97 M3 sedan
    I've driven cars a couple miles to the shop with totally whacked-out settings after doing suspension work. Think >1" toe out up front
    Some peoples' daily drivers are probably far worse than you can eyeball yours. The thing that will really make the car handle wonky is rear toe/thrust angle. Just make 100% sure you're not toed out in the rear. That should be easy enough to see visually. Having said that, the ideal (and safest) way is to trailer it there.
    And yes, you need to set ride heights before you align. If you're using stock rubber bushings you also need to torque all the suspension bolts at ride height like JitteryJoe says.
    I've eyeballed mine and driven ~5-15 miles to an alignment shop every time I've done suspension work
    Just go slow, and get the alignment as good as you can up front
    PRICE CUT on ALL FABRICS
    Valencia, CA
    Imola E36 M3 E30 Touring
    I've eye balled toe a few times, usually feels wonky but is OK for a few miles. One time I was seriously off, despite measuring multiple times, and just said it, and used my free towing to get the car to the alignment shop.
    Aug 2013
    1999 BMW M3 Coupe
    Eyeball is fine. When I did my whole bushing refresh plus steering rack last year I did an especially quick and dirty front toe adjustment which turned out to be pretty comically off on one side (I think it was like 5mm toe out or something). Had to keep the wheel slightly turned to go straight. Still drove just fine the 15 miles or so to the alignment shop. So yeah, try to do better than that but it doesn't have to be remotely close to perfect to still drive ok.
  1. Alignment change while driving
    By RobbieE36 in forum 1991 - 1999 (E36)
    Last Post: 07-07-2017, 05:28 PM
  2. Very rough idle and no power when driving, strong gas odor
    By Gunslinger64D in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 08-07-2014, 09:46 PM
  3. Drive it home - don't txt & drive
    By Kevlar in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 09-09-2010, 04:28 PM
  4. I just got home from a test drive, problem?
    By OOMPH333 in forum 2001 - 2006 M3 (E46)
    Last Post: 10-10-2009, 09:25 AM
