Results 1 to 5 of 5
Thread: 01 740il stall stutter save
    Feb 2019
    Clarkston, Michigan
    2001 740il
    Hello, all. I picked up this car in early December and just recently it started doing something I think is strange. As of late it seems to idle low on a cold start, between 700 and 900rpm. What I've noticed is, if I start the car and let it warm up to normal temp, and I mean the needle is in the middle of the temp gauge, it seems ok just a low idle. But if I put a load on it before then, anytime I come to a stop or just let it idle it drops rpm and almost stalls then spikes rpms to save itself. When this is occurring I can hear a whooshing sound almost like air brakes on a semi coming from under the intake manifold it sounds like. Once normal temp is reached this goes away but idle is still low. No warning lights come on. I've cleaned the original maf and also threw in a new one, acts the same with either one. Any help diagnosing this is much appreciated. I'm not sure where to start looking and cannot afford taking it to bmw. Thanks.
    Rutland, Vermont
    E30 E38 E46 E85 F150 GTI
    Could be intake manifold gaskets or throttle body gaskets. They will harden with age and seal poorly at cold temps. Once they warm up can seal up better. Not expensive.
    2000 740i Sport | 2004 330xi | 1988 325i Vert | 2003 Z4 2.5 | 1995 Ford F150 | 2018 GTI
    Feb 2019
    Clarkston, Michigan
    2001 740il
    Thank you!
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    Here's how to check if you have a vacuum leak:
    ...and here's how to fix it if you do:
    My BMW Repair YouTube Channel
    Feb 2019
    Clarkston, Michigan
    2001 740il
    Thank you! Those will definitely help me. I can't thank you enough!
  1. 01 330ci stalling problem
    By Shady3One3 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 09-19-2006, 11:16 AM
  2. Brake Lights on 01 740iL
    By ///M3Dave in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 08-22-2005, 07:50 PM
  3. is 85k miles excessive on an 01 740il?
    By watchbill in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 06-05-2005, 12:56 PM
  4. is 85k miles excessive on an 01 740il?
    By watchbill in forum 1995 - 2001 (E38)
    Last Post: 06-04-2005, 11:55 PM
  5. New Bolts for my 01 740il?
    By zyl8tr in forum 1995 - 2001 (E38)
    Last Post: 04-20-2005, 01:19 AM
