RM European Auto Parts
Results 1 to 9 of 9
Thread: Fluid for 2004 330ci 6 speed Manual transmission fluid
    Feb 2019
    Wisconsin
    Bmw 330ci
    Just bought a 330ci 6 speed Manuel what would be the best transmission fluid and would it cause damage to change it?
    dworthy's Avatar
    Nov 2010
    Grafenwoehr, Germany
    16 220i 05 325it 05 M3
    Welcome to the Forum!
    The correct transmission fluid is BMW MTF-2 Fluid.
    Now that stuff is rather expensive, so you will hear folks recommend Redline MTL 75W-80.
    I have only used the MTF-2 Fluid from BMW, since I have two cars that use the same stuff, the 5 quart jug was perfect.
    Darin
    Current:
    Past:
    79 525 euro Green/Green RIP
    M-Flight Member
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    I highly recommend Redline D4ATF. ATF? Yup, especially since you’re in the cold climes.
    Go to www.redlineoil.com and click on the menu to get to “find products for my car.” You’ll need 2 quarts. Buy them on Amazon.
    I’ve been using Redline products since the 1980s. Its products are top notch.
    NW suburban Chicago
    hiss by my window
    Escobar or Noriega?
    Jun 2002
    Aberdeen, NC (yes, again)
    E39M5, E500 4WD
    I'm good with RedLine MTL, or RedLine D4, or, as Turner recommends, a 50/50 mix. In my own manual transmission BMWs, I use RedLine MTL.
    Chris Powell
    BMWCCA 274412
    Mar 2003
    St. Joseph, Mo.
    95 m3+, 03 ZHP, Mk4 Tdi
    Quote Originally Posted by ross1 View Post
    Escobar or Noriega?
    Escobar, all the way....
    i've had great success with D4 as well - and know folks that have used the mix and been happy too!
    Joppa, Md
    99 M Coupe,04 K1200rs
    LOL, all you experts cleared that up, use atf or mtf, or a mixture. I laughed at the ATF sticker on my manual tranny, I guess planetary gears are gears,too..
    dworthy's Avatar
    Nov 2010
    In the old school days, we used to swap fluid every time you changed the engine oil. 75W-90 for the summer, and ATF for the winter for smoother shifting.
    Darin
    Current:
    Past:
    M-Flight Member
    Joppa, Md
    My Midwest farmer buddy in the Army told us of crawling under tractors in the winter with a torch to heat crankcases! old school viscosity adjustments.
  1. Replies: 1
    Last Post: 02-25-2015, 12:21 AM
  2. anyone change the manual transmission fluid themselves?
    By rpM in forum 1992 - 1999 M3 (E36)
    Last Post: 03-17-2010, 10:30 PM
  3. changing manual transmission fluid
    By dmw in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 10-18-2002, 05:24 PM
  4. Which Manual Transmission Fluid??
    By ///Mikl in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 10-10-2001, 05:04 PM
  5. Which Manual Transmission Fluid??
    By ///Mikl in forum 1992 - 1999 M3 (E36)
