Results 1 to 13 of 13
Thread: Wheel Speed Sensor issue
    Mar 2012
    Seattle, WA, USA
    2000 BMW 740iL
    Hello all,
    I recently purchased a 2000 740iL Super nice, love the car. I used to have a 98 740i and the engine took a poop on meh. Anyways, on the 2000 740iL. Speedometer doesnt work. All three lights on in dash. I hooked up scan tool and read code. Left rear speed sensor not transmitting signal. So, ordered and replaced wheel speed sensor. First time I started the car, all 3 lights out. (Did not get a chance to drive) started car next day. All 3 lights on in dash and no speedometer still. So i uplugged sensor and do not have 8 volt reference voltage at LR. I do not have at RR either, but RR works fine and shows wheel speed on scan tool. My question is how can i condem the module? i have the wheel well removed and all wiring looks intact. any pointers on how i could track the issue down?? Ive cleared the codes and tried. still get left rear no transmit signal code.or how can I test the integrity of magnet for sensor that's in the bearing/hub
    lA, ca, lA
    BLK 01 sp, 20 Trail Boss
    2 things I can think of, Did you clean out the sensor hole before you put in the new one ? lot's of crap was in mine also did you buy oem ? lots of folks have had problems with after market
    Mar 2012
    Seattle, WA, USA
    2000 BMW 740iL
    Nothing in the hole that I could see. I did blow out with air. I did buy OEM. Resistance value of this sensor matches that of the right rear sensor. And that of the original sensor.
    May 2003
    Texas, USA
    '01 740i, '99 528iT
    Unless others chime in with contrary advice, I'd say there is absolutely nothing wrong with your speed sensors. Instead, you have a faulty brake module giving you bogus readings. It'll need to be rebuilt. Send it to Module Masters or similar. I had the same experience with my E39.
    Frankie
    Texas, USA
    frankies-bmw.com
    Mar 2013
    Sonora, ca
    2001 740il
    Quote Originally Posted by Frankie View Post
    +1
    Feb 2009
    KC North, MO, USA
    1996 740iL
    Swap the LR and RR sensors and see if the speedo works. RR works the cruise. As stated though, all three lights often indicate the module is bad.
    Mar 2012
    Seattle, WA, USA
    2000 BMW 740iL
    Quote Originally Posted by Mayorchuck View Post
    I put the LR in the RR spot and still showed wheel speed.
    This brake module is attached where all the brake lines meet correct?
    Feb 2009
    KC North, MO, USA
    1996 740iL
    Confused. The idea is to put the passenger side sensor in the drivers side to see if the speedo works. If you did this and it does not, the culprit is probably the module. Yes, on the location of the module.
    Mar 2012
    Seattle, WA, USA
    2000 BMW 740iL
    I already had LR pulled out. So I placed in LR spot and still had wheel speed. Which tells me that the LR is working. So putting RR in LR spot wouldn't be necessary if I took LR and put in RR spot and the RR still functioned.
    Feb 2009
    KC North, MO, USA
    1996 740iL
    Sorry,I thought we were talking about you test driving each time and the speedo was now working. Here is the best thread I know of on the subject if you haven't seen it:
    https://www.bimmerfest.com/forums/sh....php?p=4205801
    Mar 2012
    Seattle, WA, USA
    2000 BMW 740iL
    Thank you. I will definitely read that.
    Here's an update.
    Started the car this morning. Everything worked perfectly. About 5 minutes later. All three lights came on and no speedometer. . I'm convinced it's the module at this point warming up and stop working.
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    Yes, that's normal behaviour for a failing module - as is reporting false error messages - more info here:
    https://www.meeknet.co.uk/E38/ABS/Index.htm
    My BMW Repair YouTube Channel
    Mar 2012
    Seattle, WA, USA
    2000 BMW 740iL
    0265950001
    Does the replacement have to match the above part number? I found one that is a 0265950002. I have programming capabilities so that's not a big deal.
  1. wheel speed sensor issue
    By thedude60126 in forum 1996 - 2003 (E39)
    Last Post: 07-07-2014, 08:31 AM
  2. Need help. RF ABS Wheel speed sensor issue. Options?
    By epwebb64 in forum 1995 - 2001 (E38)
    Last Post: 03-15-2014, 09:31 PM
  3. e90 Possible Wheel Speed Sensor Issue
    By curtisk70 in forum 2006 - 2012 (E90, E91, E92, E93)
    Last Post: 12-26-2012, 09:21 PM
  4. Wheel Speed Sensor Issue, Transmission Failsafe
    By ZackTheRipper in forum 1995 - 2001 (E38)
    Last Post: 11-09-2012, 09:48 PM
  5. Removing wheel speed sensor issue
    By flyfishvt in forum 1991 - 1999 (E36)
    Last Post: 08-28-2012, 05:02 PM
