Results 1 to 3 of 3
Thread: 08 E90 No Start - A0C1
    Feb 2019
    Cincinnati
    2008 328i 2002 330 Vert.
    ......New to forum!! Got my first BMW. Can't wait to get it on the road! Previous owner told me needed starter.
    Removed old starter, took to autoparts store and confirmed was bad. Installed new starter and had it checked out prior to installing.
    I also replaced battery and coded it with Carly. ......Car won't start? Only code get it A0C1
    I did double check my work and all looks good.
    Any thoughts would be great.
    Feb 2019
    New Zealand
    2005 E90 320i N46
    Do you have INPA?
    Not cranking?....
    Earth strap nearest starter or fuse.
    Cranking but no start?....
    Spark & Fuel?
    check Fuel pressure at low pressure pump and high pressure pumps....injectors actuating?
    Spark at plug?... check crank sensor.
    (Listen for low presure fuel pump when opening door/resetting fuse...should quietly buz until up to pressure.
    If no buz check fuse and relay in glove box. Still no buz replace low pressure fuel pump sensor.
    Still no buz check power by back probing pump at tank.
    If power but no buz replace lpfp.)
    Check Compression, Cam sensors if compression is good + fueling, with spark and not starting.
    Good luck!
    Feb 2019
    Cincinnati
    Thanks....I'll get working tonight.
  1. Replies: 7
    Last Post: 12-30-2010, 04:22 AM
  2. Is there a way to mod a 328xi 08' e90 w/ 2 exaust tips to have pic [56k] ....
    By alchemist007 in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 06-06-2008, 08:41 AM
  3. 08 335XI Hard Starts
    By ResidentGen in forum 2006 - 2012 (E90, E91, E92, E93)
    Last Post: 05-24-2008, 12:06 AM
  4. '08 E90 Pricing at Denver area dealerships?
    By SAM67 in forum 2006 - 2012 (E90, E91, E92, E93)
    Last Post: 12-04-2007, 12:01 PM
  5. does a e90 engine start button light up? any pics?
    By takem2church in forum 2006 - 2012 (E90, E91, E92, E93)
    Last Post: 03-04-2007, 10:34 PM
