Results 1 to 17 of 17
Thread: 1995 E36 M3 CM Race car for sale
    Mar 2012
    Houston, Tx.
    1995 E46 M3 race car
    SOLD!!
    I've decided to sell my 1995 E36 M3 CM class race car. Car was originally built by VAC. It has a fully built S54, Schrick cams, stage three head, CP pistons, Arrow rods, DLC followers, Motorsports headers, a clone Motorsport airbox, Motec ECU, Peterson dry sump setup. Fresh SS oil lines to and from the oil tank. New Ignition Products coils. Fluidyne radiator, VAC aluminum expansion tank. Motor has approx 30 hours on it. Compression test had a high cylinder of 212 psi and a low of 203 psi. Motor dynoed 330 rwhp on VAC's Mustang dyno. As you well know that number would be much higher on a Dynojet unit.
    VAC built 4:10 4 clutch motorsport ring and pinion, Rogue diff cover.
    Spherical bearings everywhere, all chassis weld in reinforcements have been done.
    ATL fuel cell with brand new electric fuel pump, new cell foam and new SS fuel lines.
    Cobra Suzuka seat, Schroth belts.
    Fire suppression
    JRZ triples, fresh rebuild
    Two sets of wheels, one is a forgeline three piece and the other is a set a Enkei. Both are 18x10. One set of Nitto 01 and one set of Maxxis RC-1's. I have another set of RC-1's in the box brand new.
    AP brakes, six piston up front and two piston on the rear. Rear brake bias adjuster. New set of pads in the box.
    Fiberglass doors, hood and front fenders.
    Transponder, Stack dash
    Professionally rewired throughout.
    Samaonas Dogbox 5 speed transmission. Race ratios with custom shifter, roughly 15 hours run time.
    Brand new Tilton OT-11 185mm Cerametallic racing clutch, brand new flywheel, brand new slave cylinder.
    New uprights, new front wheel bearings
    New lower Bimmerworld control arms with the revised bump steer setup, new Bimmerworld outer spherical tie rods.
    New power steering pump with the Bimmerworld AN power steering kit.
    Car was recently painted and has xpel on the front clip.
    BMW CCA Club Racing Log book. Cage is legal for NASA, SCCA and Club racing.
    I've owned the car for almost four years and driven four weekends. I used it as a DE car and I'm old and slow.
    I'm unable to post pictures but I have many, if you would like some please email me and I'll send them. deanrobinsongt3@comcast.n
    Springfield, IL
    '95m3(Avus)/996tt/4.8is
    They should put this thing in a museum given it has EVERYTHING YOU COULD DO TO AN E36. Wish you could host pictures and add a link. Want to see this beast.
    Email me at bavariane39 at gmail dot com some pics and I will see if I can add them.
    May 2003
    Tampa, FL
    E92 M3, 970TT
    Unfortunately out of my range... but I want to see some pics too. Sounds like an amazing car.
    Edit: found it on RJ... looks like a pretty amazing build. Will watch for sure.
    Mar 2012
    Houston, Tx.
    Someone asked about transmission ratios in the Smasonas dog box here they are:
    1st 2.40
    2nd 1.789
    3rd 1.429
    4th 1.174
    5th 1.000
    Mar 2012
    Houston, Tx.
    I have lots of pictures if anybody wants to see them, just email me. deanrobinsongt3@comcast.net
    Mar 2012
    Houston, Tx.
    I'm open to reasonable offers.
    LV, Pa
    944 Turbo
    This car was affectionately known as the “Silver Bullet”
    It was built years before S54 swaps were common (2008?) and refreshed 4yrs ago before current owner purchased
    It made 375rwhp on a dynapak hub dyno with a beautiful flat torque curve even without VANOS
    Northeast PA
    3 - E30 M3s, '04 Ford F350, '06 Audi A3
    That is quite the hot rod.
    Free bump, car sounds pretty awesome.
    You should definitely post some pictures.
    jimmy p.
    88 E30 M3 Zinnoberot - street
    88 E30 M3 Lachsilber - SCCA SPU
    87 E30 M3 Prodrive British Touring Car 2.0 Litre
    04 Ford F350 - V10
    06 Audi A3 Brilliant Red / 2.0 / DSG
    Mar 2012
    Houston, Tx.
    Price has been dropped to 37k.
    Mar 2012
    Houston, Tx.
    Car is still available.
    Jan 2003
    jersey
    99 blown cobra
    Can u provide me with the approximate weight of the vehicle? Is the tub original or has it been repaired? Thanks
    Mar 2012
    Houston, Tx.
    Weight is 2865 lbs. Tub is original to my knowledge, it certainly shows no sign of repair.
    Mar 2012
    Houston, Tx.
    Price lowered to 33k.
    Mar 2012
    Houston, Tx.
    Mar 2012
    Houston, Tx.
    Bump.
    nj
    332ti , M3 LTW
    Shot you an email today.
    Bill M.
    Mar 2012
    Houston, Tx.
    Big price drop.
  1. E36 E36 M3/GTS2 Race Car Part Out!
    By Spec3HOR in forum Race Cars & Track Parts
    Last Post: 10-02-2013, 02:46 AM
  2. 1995 E36 M3 GTS2 Race Car
    By Designconcept in forum Race Cars & Track Parts
    Last Post: 05-06-2013, 10:53 PM
  3. M3 E36 IP/ITE Race Car For Sale
    By M3Phil in forum Race Cars & Track Parts
    Last Post: 09-13-2010, 01:20 PM
  4. BMW E36 M3 LTW Race Car for Sale
    By JSofro in forum Race Cars & Track Parts
    Last Post: 11-15-2005, 11:39 AM
  5. E36 M3 PTG Race car for sale??
    By TurboBMW3 in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 06-08-2001, 01:51 PM
