Gentlemen,
I am getting set up to complete a 5 speed swap in my '77, and want to verify that early cars only have the small needle bearing instead of the more traditional looking bearing. This was all I removed, but RealOEM seems to show both. Thanks for the help!
-Roy
The Pilot bearing for earlier models had the small needle bearings, later models use the traditional looking bearings.
Randy
i believe you can use either, needle or ball bearings. both appear to be 12x32mm.
over the years, especially older vehicles, i've seen more solid bushings than bearings being used for pilots, so 'traditional looking' would be a bronze bushing and not a bearing.
FWIW, the input shaft bearing is at the big end of the input shaft, inside the trans, the front small side of the shaft is held by a pilot bushing/bearing.
Tom D
77 e21 - m42
88 e30m3
04 330 dinan3
84 r1000rt
02 r1150rs
all of them gray
14 f800gsa - red headed stepchild!
Thank you sir. Parts are on the way, hopefully another e21 will be back on the road soon.
My car has a smaller diameter bearing (OD) than, I'm assuming the later cars have. Sorry for any confusion I caused by using improper nomenclature, and thanks for the education.
Luk Rep Set 03-002 Clutch Set is good for 1977 -1985 1.8L and 2.0L, 320i and 318i and comes only with the traditional bearing. I have Luk Rep Set installed and a new Kit for that day, plus a new BMW flywheel 1 of 6 in the world when I bought it from FCP Euro-thru there BMW dealership contact--now I think they are all gone. What I like about Luk as opposed to other Clutch Kits as Luk goes a set further-they balance the whole rotating assembly.. Shops around here that offer lifetime replacement used Luk. I dont recommend piecemeal like some shops do getting the cheapest part for each in the clutch kit--there warranty of one year--says it all.
Randy
Yes Okie, and the hole is not in the crankshaft, its in the big weight that smoothes out vibrations on the crankshaft assembly--Big Harmonic Balancer,,the small weight in the front contributes some smoothing- not even close though to the back big weight which has the holes for the flywheel and the pilot bearing, its driven on and sometimes bolted to the back end of the crankshaft.
As too the big weight in back- the actual harmonic balancer in difference to vocabulary started by laymen that seems to continue--I was at a shop that experimented with the big weight and actually grinded it down to get mass - weight off of it on a motor rebuild they did on the side--once they lightened it-- they assembled and attempted to start the car--it would not start--they then put back in the regular weighted balancer and the car started up--so that weight is specific for a stock motor for more reasons than smoothing vibrations... Now you have a new feather in your cap.. They had an inventory of identical crankshafts with the big weight on it.
Randy
Before it comes down to "HOW DO I GET THE DAMN PILOT BEARING OUT? !!"...
Please read this, see post #15 for pics, instructions ::
https://www.bimmerforums.com/forum/s...earing-removal
Tbd
If it's just a standard ball bearing, I've used a slice of bread, a 1/4" drive socket extension, a 10mm deep socket flipped backwards, and a hammer.
2112AB00-1B19-46A5-96F3-BA948ADB7155 by hatchethairy, on Flickr
91 318is
83 320is
Well Took an extra couple of days, but here is the difference.
And the tool that made removal dead simple.
well worth the investment in my opinion.
Nice tool to have! Wish I had one at the time
Tbd
Indeed I have set like that for that day-blind hole pullers from very small to large diameter with the slam weight.
Randy
