Results 1 to 25 of 36
Thread: DKM Twin Disc Clutch Opinions
    Feb 2016
    Rogers AR
    1995 BMW M3
    I'm looking into buying a DKM twin disc clutch for my turbo m3 that i want to drive on the street for most of it's life.
    Does anyone have any experience or hear say on these clutch kits?
    They seem very affordable and from what i have seen on VW not too stiff for street driving. I searched for some reviews, but haven't really found any. Possibly they are just now beginning to hit the US market? I don't know.
    I'm hoping for around 500whp-600whp once everything is squared away
    San Antonio
    Z3M Coupe & Roadster
    MaxPSI sells these. I was going to ask on their FB post about how much tq it holds. They do offer two different clutches too organic and ceramic. I haven't heard about this brand until I saw their post on the e36 f/i fb page. I too have not heard any reviews of this clutch.
    Feb 2016
    Rogers AR
    1995 BMW M3
    same here, that's kind of the first time i have seen it. On eBay with the organic disc it states it will hold up to 650 ft/lb of torque.
    I've seen some reviews of their VW application, but it wasn't very many and none for the BMW community
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    Isn’t this the same clutch CES has been selling for a few years? People like those. I have driven one with ceramic discs. Ceramic is better for drag racing, but maybe twin discs are harder to smoke when drag racing. I smoked some single discs before going to a ceramic single. Organic is easier to drive, but they cersmics I have driven aren’t bad in my opinion. Will get some squeaking and it won’t be quite as soft engagement off the line.
    Feb 2016
    Rogers AR
    1995 BMW M3
    It looks like it could be, but it says it's made in house and under the name of CCI. No clue if they have any affiliation but looks very similar
    Has the same price of $895 for the twin disc organic and says it's capable of 800whp and 600wtq
    Apr 2006
    Minnesota eh?
    86 325es
    It is the same one that max psi and Ces sells. Mike from max psi posted on Facebook that they will be selling them for the same price now.
    Jun 2004
    The D, MI
    97 M3, 98 328i, 13 Cruze
    I've got twin organic. No complaints. Drives nice and made the car significantly more streetable.
    Nov 2008
    Indiana
    97' 328is, 07' Titan
    Same as Kevin said.
    I can't say for it's 600 torque capacity as I was nowhere near that but it worked for the power I'm at.
    1997 328is - Megasquirt PNP, Holset HX35, Deka 80lb injectors, SPA T3, Precision PW39 WG, Synapse Synchronic BOV, DKM Organic Twin Disc Clutch, Innovate LC-2 W/B, Mishimoto Intercooler, Mishimoto Catch Can, Mishimoto Rad, Devils Own Meth, Porsche 911 calipers with E46 M3 rotors, Corsa Exhaust
    Feb 2016
    Rogers AR
    1995 BMW M3
    Quote Originally Posted by somebody5788 View Post
    Same as Kevin said.
    How much power do you have currently? Just wondering
    Jun 2005
    New England
    I would not worry about the twin organic unless you are drag racing or have or plan to have over 600 lbs rwtq. Drag racing really stresses the car. I never had an issue on the street, but at the strip, I fused clutches, twisted driveshafts in two, broke 188mm differential output stubs, and broke ZF320 transmissions.
    Feb 2016
    Rogers AR
    1995 BMW M3
    I have no plans on drag racing. if i go to the track it would purely be for fun and ease into on the line, so i think i would be ok
    I actually found them on eBay for $835 shipped
    Nov 2008
    Indiana
    Quote Originally Posted by lbennyboobool View Post
    Over 400whp. Under 500. That's all I know
    Feb 2016
    Rogers AR
    1995 BMW M3
    Perfect! Hopefully i'll be around the same if not a little more
    The Plains
    MaxPsi M3
    I have the twin disc ceramic version. Before it, I ran the south bend feramic clutch. Pedal pressure is much lighter, it only makes a little bit of noise when the clutch is engaged. It is a heavy clutch but driveability is really good if you daily it. It has held >600 whp very well.
    Sent from my SAMSUNG-SM-G930A using Tapatalk
    Frederick, MD
    '87 e30, '02 e39 Dinan
    Thank you guys for this thread. Been eyeing up the CES one. Planning on using the e36 one for the m20. Im out clutch capacity around 380whp/320wtq (south bend stage 3) and this seems to be the next best solution.
    Capital Driving Club Car # 102
    How to turbo your car:
    Step one. Install ecu and learn to tune and or have it tuned.
    Step two. Install injectors and retune.
    Step three. Install turbo parts and bits. get it running with out leaks. DO NOT DRIVE IT. Idling should be ok
    Step four. Retune car
    Step five enjoy
    Mar 2013
    Upstate NY
    M3
    Idk if I'm just lucky or what, but my FX Stage 3 is holding 620whp and 580wtorque. I've not had any issues yet and I'm at 20k miles boosted. ???
    /e never launched with drag radials etc.
    Feb 2016
    Rogers AR
    1995 BMW M3
    I've heard the FX stage 3 is a little hard to drive as a daily. How do you like the clutch feel on it?
    Mar 2013
    Upstate NY
    M3
    It's fine, stock feel pedal. It does chatter like grab slip grab jittery motion for a little while but smooths out very nicely.
    Don't quote me on the stage 3, it could be 4 idk. Ceramic 6 puck.
    Nov 2008
    Indiana
    The problem is an FX clutch is an old design with some flaws and heat can warp the pads causing them to eat up the pressure plate and flywheel until it just doesn't hold. So they grip if you never slip it but if you slip it too hard just once it can permanently damage it. Compound that with slightly lower QC and I'd just rather get a clutch that drives 10x nicer and guaranteed will last longer ultimately it's cheaper to run the twin disc since it's nearly guaranteed it will last 3x longer.
    Mar 2013
    Upstate NY
    M3
    I have no doubt there are new and improved designs and obvisouly anything with an EBAY stamp could be sketchy. Some just get lucky, I got lucky. I consider it a win, 20k miles, track driven etc. Holding WELL over advertised power. Don't be an idiot with the clutch and they will last. Now all that said, I'd probably not try to do any REAL drifting with it, don't play games as this is a special circumstance.
    Frederick, MD
    Ive reached out to CES to confirm this could work. Does any one know if this will work on an m20?
    Step five enjoy
    Apr 2006
    Minnesota eh?
    86 325es
    Quote Originally Posted by euro2fast4u View Post
    It will work. Just need to swap to an M50 starter.
    Frederick, MD
    Thank you Sir!
    Step five enjoy
    Apr 2006
    Schaumburg, IL 60193
    99 M3 cpe;15 Avalon Ltd.
    How is the DKM Twin Disk with chatter? In particular the twin organic disk? It seems like the engagement is stock like, but don't see much info on chatter.
    MODS: AA SC'D Rotrex C38-92 Stage 2 (60# injectors)==M50 Manifold==Snow Performance Stage 2.5 Meth Kit==Schrick 264/256 Cams==AA Ceramic Coated Headers==AA Trackpipe==Eisenmann Race 2x76==Clutch Master FX250 Clutch==Euro Oil Cooler==MANN Provent 200 Crankcase Catch Can==AA DSB== X-Brace==ZKW 6000K HID FX-R retrofit with Orion V2 L.E.D. Angel Eyes==Euro clear signals and tail lights==M-Tech Pedals and E-Brake==BBS RGR Diamond Black 17x8; 17x9 staggered==Leather Z Gauge Kit (oil temp, oil press, voltage)==Rally Road Guage Pod (steering wheel mounted with AEM AFR guage and Prosport boost gauge)==Cut-ring head gasket==Head refresh done by Autohead Performance==KW V2 Coilover Kit
    Current with 85mm pulley and meth: 450 whp 365 wtq @ 13 psi on a Dynojet at Performance Eurowerks in Buffalo Grove, IL.
    Previous: AA Mustang Dyno Tuned in Miami, FL @ 10 psi on 93 pump made 392whp 325wtq (
    Performance Eurowerks Dynojet in Buffalo Grove, IL was 410 whp and 325 wtq @ 10 psi)
    Jun 2005
    New England
    It’s a nice clutch. The heavy weight helps dampen the noise. No traditional chatter. Beware that twins will tend to be noisier than singles because two discs and a floater have to move.
  1. E36 JB Racing Ultra-lite competition Flywhel and racing twin disc clutch kit
    By silvere39bimmer in forum Drivetrain & Transmission Parts
    Last Post: 04-03-2011, 11:01 AM
  2. FS NJ : Clutch Masters Stage 6 FX600 Twin disc clutch kit for E36 M3
    By BILLYhoang in forum Drivetrain & Transmission Parts
    Last Post: 01-23-2008, 09:35 PM
  3. ClutchMasters Twin disc clutch kit/ flywheel *NEW*
    By Iding SIII in forum Race Cars & Track Parts
    Last Post: 09-04-2007, 09:50 AM
  4. FS: E46 M3 Twin Disc Clutch w/ LTW Flywheel - Clutchmasters FX600
    By HiRide in forum Drivetrain & Transmission Parts
    Last Post: 08-15-2007, 10:51 PM
  5. Replies: 7
    Last Post: 04-18-2007, 08:21 PM
