Results 1 to 12 of 12
Thread: m62tu wont start , camshaft , crankshaft sensors error code
    Feb 2019
    warsaw
    540i 2002
    m62tu wont start , camshaft , crankshaft sensors error code FIX
    hi all
    My car stopped on the road few days ago , i was able to turn engine on again just for few secound then engine is off . After 30 minutes i was able to keep engine on for about 30 secounds then again is off
    Today in the morning i wanted to check if cold car is still alive but nothing , i can only hear crank,crank,crank , i trying 30 secounds but still only crank and engine wont start.
    I got two error codes:
    -camshaft sensor bank 2
    -crankshaft sensor
    question is :
    where to start ? if i will disconnect one camshaft sensor then my engine should start ? of course if it problem with camshaft sensor ? i know this ,,trick'' works with engine with only one camshaft sensor , what about my engine where you have two cam shaft sensors ? it will work ?
    or it just crankshaft sensor problem ?
    sorry for my english
    JimLev's Avatar
    Sundance Mesa, NM
    00 540/6, '16 Highlander
    What are your actual codes?
    A bad cam sensor shouldn't prevent the engine from starting however a bad crank sensor will.
    Feb 2019
    warsaw
    540i 2002
    its german
    -nockenwellengeber bank 2 - camshaft sensor bank 2 -> error accurances 18
    -kurbelwellengeber - crankshaft sensor -> error acccurances 2
    Feb 2019
    warsaw
    540i 2002
    Engine is no longer dead...... strange story but i will try to explain with my poor english
    Car was used for two years only in short distances , 4 km in one way and 4 in another way anyway so there is result....
    we replaced both sensors -camshaft and crankshaft but engine is still dead so we decided to check engine compression and...... 1 cylinder 1 bar , 2 cylinder 3 bar , 5 cylinder - 8 bar , 6 cylinder 5 bar , 7 cylinder , conclusion ... engine is dead but mechanic told me that he had many causes where cars were used on short distance and losted compression just like that coz over grease cylinders. So.... i decidet to try turn engine on again and......... engine is on then immediately i push gas pedal down ..... 3000 rpm , 5000 rpm i keept engine like this for about 20-30 minutes and everything is smooth and ok . anyway there is no longer crankshaft sensor error code afted sensor replecament.
    Oct 2017
    Beaverton, Oregon, USA
    2001 E39 540i A, 207 k
    Moral : take the car on a long drive of about 100 Km weekly...
    Sep 2009
    Colorado
    99 528i, 90 ZR-1 Vette
    You kept your engine running at 5000 rpm for 20-30 minutes? YIKES!!!!
    Apr 2018
    Socal
    00 528i, 01 540i
    Did you do another compression check after?
    Feb 2019
    warsaw
    540i 2002
    Problem solved
    Yes , we tested only 3 cylinders after engine warm up and everything was fine , in friday boss wanted to close garage so we didnt get more time to test but now engine is like new.
    Today again car didnt want to start again sensor camshaft bank 2 code on my computer and guees what cause problem with sensor error and no engine start ? engine computer plug under hood yeah guys . I found out that plug is dirrty , something like green oil or something , hard to describe it , it means that camshaft sensor had no proper connection with engine computer. we cleaned engine computer plug with special plug spray and engine is like new, there is no longer sensors error code , everything is ok now. yeah , so there was no need to buy new sensors so i wasted 200 euro for nothing but at least my car is ok again
    Nov 2011
    Derby UK
    1999 BMW540 Supercharged
    That green oil stuff on the dme plug sounds to me like its been wicking the coolant fluid up the wiring to the dme.
    1999 540 Auto with Eaton M112 supercharger
    Airlift 3H/P management, M5 steering box, M5 LSD, Eibach/Dinan front and rear anti roll bars, PM Modifich door boards, 4 Eton 6.5s, Sound Magus VS3500.1, 2 x 10" Kove audio subs, Alpine ICS X7 Headunit, 19" BBS Hammer Sports RT245/RT246, Muffler delete, electric coolant fan.
    Feb 2019
    warsaw
    540i 2002
    hmmmm my coolant is red colour for at least last 4 years
    Oct 2017
    Amazing , how basic engine hygiene clean up often solves the most intractable problems...
    May 2014
    Hockinson Washington
    Two 2003 540i6 Msports
    Quote Originally Posted by Chedley View Post
    Works on airplanes too. "Cleaned connector, ops check good". Lol
    I do not believe in a risk free society where the thrill of living is traded for the safety of existence. Nick Ienatsch
    The law does NOT determine "right" from "wrong". They are unrelated.
    If you put cheap parts on your car, you will soon have a cheap parts car.
  1. Help! - crankshaft sensor error code
    By lagunae34m5 in forum 1992 - 1999 M3 (E36)
    Last Post: 06-26-2013, 12:35 AM
  2. Replies: 3
    Last Post: 07-22-2011, 08:03 AM
  3. Replies: 1
    Last Post: 06-15-2008, 05:13 AM
  4. HELP - Crankshaft Sensor Error
    By cal_guy19 in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 12-30-2003, 05:13 PM
  5. O2 sensor error codes
    By cos M3/4 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 06-20-2003, 01:34 PM
