Results 1 to 3 of 3
Thread: RDC (TPM) Module
    Feb 2019
    Worth, Illinois
    2-2014 X3
    Angry RDC (TPM) Module
    Hi All- I have been curiously searching for information about the RDC module in my 2014 X3. I had a catastrophic failure with mine which included excessive current draw alarms and the smell of hot electronics. Then the fabled "TPMS malfunction" with the display showing to check my air pressure in all four tires illuminated.
    During my research I found hundreds of people with similar failures. Most importantly tied to corrosion inside the RDC module. I decided to investigate the module on my car and found indeed, my RDC also failed due to corrosion. Also the connector on the inside if the module appeared to start melting.
    I contacted the dealer who offered to replace the module and program it for about $1000. I asked him about this issue. His exact statement was "we see this all the time".
    During my research, I also discovered a BMW training guide. In this guide it was stated: "The antenna is waterproof which allows external mounting, usually near the center of the vehicle."
    So here's my question: If all the comments (over three hundred) around the internet and some on this forum, even a very nice video showing how to repair corrosion, and including the service department at my dealership seeing this "all the time" with corrosion problems, aren't we using this forum to demand a fix to this issue?
    I own two of the 2014 X3. When will the other one fail?
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    moved to X3 forum
    Jan 2016
    Ca
    2001 525it
    We just had a 1 series that had water in the right rear fender well are that filled with water and fried 3 modules the reason the water got in is because when body work was done the rubber piece that goes around the fuel filler pipe was not installed correctly
  1. 2007 328i TPMS RDC Control Module Location?
    By JoeyRizk in forum 2006 - 2012 (E90, E91, E92, E93)
    Last Post: 11-20-2023, 01:04 PM
  2. RDC - TPM Control Unit Replacement
    By BimmerGuy1969 in forum 2002 - 2008 (E65, E66)
    Last Post: 10-24-2018, 10:54 PM
  3. Anyone have RDC (TPMS)?
    By IcemanBHE in forum 1995 - 2001 (E38)
    Last Post: 10-13-2016, 12:44 PM
  4. TPM Malfunction-RDC/TPM control unit replacement
    By Jroe02 in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 10-02-2014, 06:01 PM
  5. TPM Malfunction-RDC/TPM control unit replacement
    By Jroe02 in forum Forum Software Questions & Suggestions
    Last Post: 09-30-2014, 12:05 PM
