Results 1 to 7 of 7
    Feb 2019
    North east
    X5
    2011 X5 air suspension issue
    Morning guys!
    when i left the house this morning i noticed my X5 was looking very low at the back end, thought there may have been a flat tyre. Started engine, looked again and the car was back to normal, after looking around the forums i found it is most likely a fault with the air suspension? i have read that if left too long it cause problems with the air compressor and may result in it needing replacing? So my question is should i take to be looked at straight away or could this just be a one off? Should i leave it a few days / weeks and see if it happens again?
    Thanks in advance, have a good day guys 😊
    Feb 2019
    North east
    X5
    Anyone?
    Jan 2016
    Ca
    2001 525it
    Well you certainly could monitor it the more common problem would be the air bag or air spring could be failing theydevelop cracks and leak. Have some body lift the car and inspect. TWhen replacing the bag you have to make sure it folds evenly around this lower piece or else it will be off and the bag will wear out in about a month
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    moved to X5 forum
    Oct 2012
    Detroit, MI
    E36, E70, i3
    On our '08 I waited until it happened more than once a week and then did it. Bought the parts well ahead of that but made time once it started happening more frequently.
    Yep. Sounds like it's time to replace the bags. We do them all the time.
    Feb 2019
    Kasama, Zambia
    2001 BMW X5 3.0i
    Well the first thing is to monitor the period when the vehicle is losing pressure in the airbags. Say, if it is happening over night, that will certainly indicate holes in the air bags or leak in the piping system. Easy to check the leaks in the piping system from your backyard. In the battery compartment you are able to see the piping and air receivers, with soap foam you are able to see leaks. I have also witnessed leaks in the Compressor unit on the solenoid distributor valves.
    All the best
  1. 01 X5 Rear Air Suspension Issue
    By onequik1 in forum 1999+ X5, X6 (E53, E70, E71, F15, F16, G05, G06)
    Last Post: 03-01-2013, 01:46 PM
  2. Touring rear air suspension issues
    By connorb850 in forum 1996 - 2003 (E39)
    Last Post: 07-14-2012, 05:26 AM
  3. Air suspension issues....
    By mikestik in forum 1999+ X5, X6 (E53, E70, E71, F15, F16, G05, G06)
    Last Post: 03-04-2012, 04:11 PM
  4. 3.0 X5 air conditioning issues
    By 1986325es in forum 1999+ X5, X6 (E53, E70, E71, F15, F16, G05, G06)
    Last Post: 07-30-2009, 01:13 AM
  5. X5 air suspension inactive
    By finchy in forum 1999+ X5, X6 (E53, E70, E71, F15, F16, G05, G06)
    Last Post: 04-06-2005, 02:02 PM
