Results 1 to 7 of 7
Thread: Is my rear wheel hub toast?
    North Carolina
    1987 BMW 325e
    As I was removing a rear wheel hub, the inner race of the bearing came out with the hub (as expected), and when I used a bearing separator to remove the race from the hub, this happened (see photo). Is there anything I can do about it, or is there a new hub in my future?
    richardodn's Avatar
    Moderator
    Nov 2008
    Lakewood, CO
    20 440ix cab, 12 X3 35ix
    It's probably fine as long as its basically still round. File off any high spots and make sure splines from the axle still fit.
    "Howdy, Folks!"
    Michigan
    2005 325Xi
    Voted : Will buff out
    Oct 2003
    Seattle
    99 M3
    ^ +1, +2 LOL!!!
    Carefully file off the high spots and you should be good. Not ideal, but it is an E30 (and not a race/track car, correct.)
    North Carolina
    1987 BMW 325e
    Right, it's not a track car but rather an E30 that gets babied quite a lot. I'll see what I can do with the buffing/filing. Thanks to all for the help.
    Mar 2012
    Hopewell Junction, NY
    1987 325iS...edan
    ​Yikes, what happened there?
    North Carolina
    1987 BMW 325e
    Quote Originally Posted by ELVA164 View Post
    As I was removing the race with a bearing separator, it was going smoothly until the last little bit, and then I started seeing metal shavings. I thought they were from the race, but when it came off completely, I saw that it was the hub that suffered damage.
  1. Replies: 16
    Last Post: 06-05-2006, 03:29 PM
  2. Rear Wheel Hub Assembly
    By cquin47 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 05-09-2005, 12:29 AM
  3. replacing rear wheel hub assembly? bearing?
    By psonio7 in forum 1991 - 1999 (E36)
    Last Post: 12-05-2004, 01:26 PM
  4. How to take the rear wheel hub off
    By mojo powered in forum 1983 - 1991 (E30)
    Last Post: 08-05-2004, 08:43 PM
  5. stripped rear wheel hub thread
    By richt in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 09-07-2003, 02:56 AM
