Results 1 to 4 of 4
Thread: Gas pedal, temp sensor, odo gears ?s
    Dec 2017
    Chicago Illinois
    2003.5 E46 M3, 1992 e34
    Hey guy,
    Just picked up a 1986 635csi. Sport package 5 speed and I am loving it so far!
    Car is overall pretty solid except for the couple things which I have questions about.
    1. My Gas pedal is very janky. You can depress it about a good inch before it actually gives the car throttle. Very loose feeling. Would this be a throttle cable issue? Or is there bushings somewhere in the gas pedal like an e34?
    2. My temp guage is wonky. It seems as if it is loose rather that not actually operating. It wants ti climb and sometimes holds but usually just sits on fully cold. It bounces around though. I think Ive read about a nut coming loose on back of it? Is that likely? Or may i have to chase down a sensor issue?
    3. Lastly for now, my odometer doesn’t work and I know I need gears, but my speedo also doesn’t work. Are these sets of gears linked or does a speedometer need different ones? Or something else to fix it?
    Thanks in advance. Heres a picture of her!
    Melbourne, Victoria, Australia
    1986 BMw 635 CSi
    My gas pedal was the same when I purchased mine - lube of the cable and pivot points near the throttle body fixed that.
    Temp gauge - check the connections to the sender at the front of the engine.
    ODO and speedo - if it was just the ODO, its most likely the gears. But with both not operating, its most likely the sender (at the diff) or the wiring from this causing problems. Speedo and ODO both run from the pulses generated from the sender.
    Hope that helps!
    Tony
    '86 635
    Dec 2017
    Chicago Illinois
    Quote Originally Posted by Tnarkowicz View Post
    Hope that helps!
    Tony
    '86 635
    Thanks for the Response Tony! Ill check out those things! As for coolant, upon looking at the wires the look pretty rough. But everything is connected. IMG_1621.jpgIMG_1623.jpg
    2nd pic is at overflow tank.
    Dec 2017
    Chicago Illinois
    Update,
    I adjusted the throttle cable giving it less slack so the gas peddle is much better.
    As for the speedo and temp gauge issue, I believe my SI board is bad or at least the batteries are, so I found a rebuilt cluster online and will just purchase that, then send in mine for core. I’d rather do this than drive with no temp gauge and circuit board electronics are the last thing I want to do.
  1. Terrible gas consumption. Coolant temp sensor?
    By whofarzed in forum 1991 - 1999 (E36)
    Last Post: 12-08-2010, 12:40 PM
  2. Exhaust gas temp sensor fault
    By 4stripes in forum 1999 - 2006 (E46)
    Last Post: 02-21-2010, 06:12 PM
  3. OBDI O2 sensor (e30, e31, e32, e34, e36), temp sensor, gas cap
    By FedE36 in forum Engines, Performance Parts & Software
    Last Post: 06-02-2009, 03:34 PM
  4. I did the gas pedal check engine test. What is lambda sensor #1?
    By yellow360f in forum 1992 - 1999 M3 (E36)
    Last Post: 01-27-2009, 01:58 AM
  5. Need help finding Intake Air Temp. Sensor
    By dbruce in forum 1992 - 1999 M3 (E36)
    Last Post: 05-19-2001, 04:52 AM
