I need a fuse panel diagram, I believe I have a few bad fuses .... 2011 535i
Hope this is allowed. https://www.autogenius.info/bmw-5-se...e-box-diagram/
Did you look for the laminated fuse index sheet that is usually folded up and inserted in a slot in the trunk's fuse box location? If you find the fuse index...it will list all the fuses in the front & rear along with all the icons (good luck figuring them out) that explains what fuse powers what that icon represents. A hint...many of the fuse icons are the same ones located around the car...for instance, the icon on the interior overhead lights are the same icon listed on the fuse index.
Just curious...where you able to find the fuse diagram BMW provided?
