Results 1 to 11 of 11
Thread: 1997 M3 Coupe sitting since 2014 **new member**
    Feb 2019
    SoCal
    1997 M3
    Hey all,
    Wanted to share my past two weekends. Pulled the old M3, E36 out of moth balls, well, the garage, sitting since 2014.
    Started with a new battery, cranked died, cranked died, I'm sure many have you have experienced this. Shot some WD-40 into the intake and it started, no idle, it would die. Once I was able to get it started revved a bit to keep it running, over 2K and it was not that bad, but a bit lumpy.
    Did the normal checks, fuel pressure √, spark plugs √ but oily on the outside. Injector number one "seeping" with the car off.
    So start the part list, pulled the injectors, had them rebuilt, rcfuelinjection.com , but #1 was toast, bought a new one, valve cover gaskets and nut seals, oil filter, oil, ATF (power steering) and spark plugs.
    Installed injectors, valve cover gaskets and nut seals, pulled the throttle body cleaned carbon build up in the intake opening by the butterfly and cleaned the MAF sensor with MAF cleaner, NOT CARB CLEANER, but still barely an idle maybe 300RPM then die. Screw it, pulled the ICV, huh, locked up. Blasted with MAF cleaner, have it a few raps with the handle of my screwdriver and clickity clickity.
    Reinstalled everything, idle strong runs great, no smoke, changed the oil, topped the power steering and changed the plugs.
    BUT....still throwing P0505 ICV, clear the codes, comes back. Anyone know why this would be?
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    Moved to E36 M3 forum from E36 forum
    Marietta, GA
    95 M3, 87 535is
    ICV probably still sticky. Might just want to replace it or let it soak in solvent.
    Jun 2010
    NY
    1997 328i
    Get an ultrasonic cleaner, use distilled water.
    MauiM3Mania's Avatar
    MauiM3Mania is online now Observer/Master Skeptic Moderator
    Jan 2002
    Central Pacific
    88M3 99M3 04M3 ITBx16
    Did I miss where you removed the liquid that used to be fuel? If not, do so before you throw parts at the car.
    88M3 AW 43k miles Project FS
    Long Island, NY
    1995 M3 - 2007 X5
    Did you treat the fuel before storing the car?
    Feb 2019
    SoCal
    1997 M3
    Just SeaFoam
    Jan 2002
    Central Pacific
    Quote Originally Posted by mattowar View Post
    Just SeaFoam
    You probably should siphon the tank dry, add a few gallons of fresh fuel and purge the fuel line.
    Long Island, NY
    1995 M3 - 2007 X5
    Just SeaFoam
    That doesn't stabilize the fuel for long term storage. That will clean the system but you probably have bad gas.
    Quote Originally Posted by MauiM3Mania View Post
    +1. Maybe throw in a new fuel filter too at this point.
    Feb 2019
    SoCal
    1997 M3
    Fuel is not the issue, the car runs great now.
    But for reference, I initially put half a can of Seafoam with 3 gallons of gas prior to putting in the rebuilt injectors thinking that would clean it out.
    Later on I put in the rebuilt injectors and the car runs great, just the P0505 ICV code after I cleaned it out. Maybe I didn't get all the carbon out of the ICV when I cleaned it out.
    Mar 2004
    SoCal, CA
    2017 M3, 95 M3
    Great to hear the car is coming back. In the same boat myself, finally resurrecting my M3 out of the garage. Been sitting there since 2015. 20190223_090005.jpg
  1. 1997 M3 Coupe-5spd-black New Mexico
    By jim66 in forum BMW Cars For Sale / Wanted
    Last Post: 12-02-2005, 08:17 AM
  2. Fixer 1997 M3 Coupe for Sale $15,900 -- Estoril, 27K mi, 5sp
    By M3_4_Sale in forum BMW Parts For Sale
    Last Post: 05-11-2002, 10:12 PM
  3. WTB: 1995-1997 M3 Coupe
    By Jason_R2 in forum BMW Parts Wanted
    Last Post: 04-21-2002, 01:14 AM
  4. FS: 1997 M3 coupe Artic Silver/Black
    By butterm3 in forum BMW Parts For Sale
    Last Post: 04-11-2002, 10:57 PM
  5. FS: 1997 M3 Coupe 5spd
    By Brandonb in forum BMW Parts For Sale
    Last Post: 08-01-2001, 02:51 PM
