Hello all,Im new to the forum and am looking at purchasing a 2005 Z4 and am wanting to know what to look out when I inspect it. Any insight would be very much appreciated. The car has 66K miles and looks very good but as we all know looks can be deceiving.
They are usually very good, so check out the normal wear and tear issues, look under neath for rust, salt on roads use etc.
If its a roadster, check that the top goes up/down properly. Ask/check to see if the top motor has been relocated to the trunk/boot. This is a good thing if it has.
Good luck with the purchase.
1999 2.8L Z3 Roadster,
2000 3.0L Z3 Roadster,
Good evening sir! I'm too looking at buying a 2012 Z4 35is. I'm doing my research on average price for maintenance. Also found some trouble with the turbos. It would be good idea to check on recalls. I'm new to the forum and I hope this helps! icemanone
I asked this a while back and really didn't get much of a response. If you are looking at a 2003-2008 this is what I found out.
These are the known weak points of a BMW Z4.
Prematurely deteriorating and cracking interior and exterior plastic trim.
Under panel body parts.
Heater for crankcase ventilation valve.
All engine gaskets, Oil filter housing, valve cover and oil pan gaskets.
Water pump .
Xenon headlight wire harness deteriorating insulation causing shorts.
Convertible top operation.
Blocked rain drains.
Soft top hydraulic motor failure .
Oil leaks of the convertible top cylinders.
Front shock towers can mushroom up. Open hood and check.
Sticky steering under warm weather.
Ticking noise on cold start.
Rear springs that are broken.
Rear axle CV boots
