Results 1 to 6 of 6
Thread: 2000 Z3, 2.8 HK Amp Question
    Johnson City, TN
    2000 BMW Z3 Roadster 2.8
    I have a 2000 Z3 2.8, with the HK Setup. I have a few questions.
    1. Which amp drives the speakers, and which one drives the sub?
    2. If I unplug one with the other continue to function?
    3. Car came with no books, so I have the code display on the radio, it's the stock cd player model. Is there a place to retrieve the code for free?
    4. anyone have the pinout for the amp harnesses.
    Explanation: Do to a poorly installed seal around the rear deck of the convertible top and trunk lid water has intruded into the trunk, and down the seat backs. The speakers behind the seats are blown due to the water, the sub box is broken, though the sub itself looks ok. The amp on the RIGHT side of the trunk was causing blown fuses. I hope this was the SUB amp. I will be replacing most of this come spring, but just need some tunes in the mean time. I'll post a picture of what I found inside the amp if anyone has any ideas.P_20190216_154341.jpg
    Aug 2012
    Kansas
    2000 m roadster 2010 x3
    If you have the dual amp system then the sub amp is on the driver side (us) trunk. The passenger side is the rest if I remember correctly. I read where others have found adapter harnesses at crutchfield. I would replace the amp with a aftermarket 5 channel and ditch the sub amp too (if applicable). This way you can use better speakers(poly)
    Johnson City, TN
    Seems to be correct. I put in a new radio thinking it might be an issue with the original unit, and I didn't have the radio code. I found however that the original radio was fine, and the code was written in permanent marker on the top. No sound though as the amp is gone.
    Aug 2012
    Kansas
    Check wedophones.com in their manuals section and see if your year is listed.
    Jul 2017
    Statesville, NC
    Z3
    I have a pair of HK amps from my 2002 2.5i Z3, that should fit. I'll sell them cheap if you need them.
    Johnson City, TN
    I appreciate it. Someone else Dm'd me and I bought one from them, and have it in and working now.
    Sent from my ASUS_X00ID using Tapatalk
  1. 2000 Z3, 2.5 Suspension Questions
    By mark8195 in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 06-07-2007, 06:10 PM
  2. 2000 Z3, 2.5 Suspension Questions
    By mark8195 in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 06-07-2007, 05:53 PM
  3. Just bought a 2000 Z3, got a few questions.
    By GnomeRogue in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 04-30-2007, 12:27 PM
  4. 2000 Z3 2.8L Questions (Buying)
    By Laoch in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 10-16-2006, 01:08 AM
  5. 2000 Z3 2.8 Hardtop Question?
    By rango44 in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 11-18-2004, 06:52 PM
