Results 1 to 8 of 8
Thread: Exhaust Drone
    Jun 2008
    Dallas, Texas
    '14 550/M, '03 540/M
    Exhaust Drone
    OK so I put a Meisterschaft GTS exhaust system on the car (catback) so from the down-pipes all the way back. (sidenote: the stock exhaust system was all one piece, and it's a big so storage in an issue if I ever want to sell the car and replace it)
    it sounds amazing on the outside, but inside the cabin I have a moderate edit: Resonance sound between 1600-1800 rpm depending on throttle. that needs to be resolved. I'm thinking about these choices in this order:
    1) wrapping the pipes in heat-resistant insulation
    2) using rubber bushings on all the mounting bolts, and
    3) if I have too, pull out the seats and carpet in the cabin and truck and install sound deadening material.
    Anybody have experience with this type of thing? Thanks.
    Michigan
    2005 325Xi
    Sounds like it's resonating with the rest of the car in a way it shouldn't, so I would think 1 and/or 2 should get you where you need to go. Or welding a heavy rubber weight on there somewhere.
    Quote Originally Posted by B4SH View Post
    If anyone knows, it's this guy who knows literally nothing about everything.
    Quote Originally Posted by fcvapor05 View Post
    Do you even OT? The mean 401k around here is probably about $6, what with all the shiny cars and $1,000 watches and donations to get other members' Volvos running.
    Jun 2008
    Dallas, Texas
    Quote Originally Posted by Critter7r View Post
    Didn't know about the weights. After doing some research I can see that would be helpful. Thank you for the feedback.
    The only way to stop a drone is to add a resonator to the exhaust.
    All the stuff you're talking about doing will only fix a vibration, not change the actual sound of the exhaust.
    Jun 2008
    Dallas, Texas
    Quote Originally Posted by White94RX View Post
    Thank you. After reading this, I questioned myself if it was a drone or resonance, and not for sure what the difference is, I found a youtube video of an exhaust drone.
    It is not a constant warbling sound like this https://www.youtube.com/watch?v=hG4dG9qTZE0
    It is a resonance at certain frequencies; it comes and goes depending on throttle and rpm.
    Jun 2008
    Dallas, Texas
    I found out that apparently the OEM exhaust has weights, so I'm going back down there on Friday and they're going to remove the weights and weld them to the new exhaust, which is lighter.
    also they already installed rubber bushings #2 on the list.
    Jun 2008
    Dallas, Texas
    FYI after we put the car up on a lift we discovered that the exhaust pipes were touching a cross support underneath the car, so we fixed that and it's much improved. We didn't need to put weights on the exhaust system. Problem solved.
    Good to hear. Without driving the car myself, it's hard to know if a person is describing a drone, just from sound, or a vibration, or resonance frequency. Thanks for updating the thread with your results.
  1. Stock exhaust drones?
    By Jason C SBB in forum 1992 - 1999 M3 (E36)
    Last Post: 06-19-2008, 10:47 AM
  2. Stock exhaust drones?
    By Jason C SBB in forum 1991 - 1999 (E36)
    Last Post: 06-19-2008, 03:53 AM
  3. exhaust drone
    By extra330 in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 10-02-2007, 03:11 AM
  4. Dinan Exhaust Drone
    By Striker169 in forum 1999 - 2006 (E46)
    Last Post: 07-19-2006, 03:09 PM
  5. Exhaust Drone
    By ///MDriver in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 11-18-2002, 12:54 PM
