Results 1 to 10 of 10
Thread: Throttle Body Coolant lines
    Feb 2014
    allentown
    99 Z3MC/00' 2.8 roady
    What is the purpose of the TB coolant lines? Can they be deleted?
    Aug 2017
    These lines are there to avoid icing of the throttle plate in really cold climates.
    I've bypassed them on 2 of my cars, will bypass on the third when I pull that intake manifold
    I also live in Arizona keep in mind... but I did a lot of research and even people in very cold climates don't seem to have issues bypassing those lines
    PRICE CUT on ALL FABRICS
    Dec 2007
    Great Dismal Swamp
    E36/7 E36/8x2 E46 F25
    Carb / Throttle icing doesn't happen in "really cold" climates. It takes extreme humidity, which isn't there in sub-zero weather (or Arizona). The typical danger point is 35-45F, but I've had carbs ice on my bikes as high as 50F. Ambient temp has nothing on the sudden temp drop across a closed throttle plate. The one thing that is required is near 100% humidity.. That and a temp drop of +50 to -30 in like half an inch is what causes the issue.
    /.randy
    Oct 2012
    Louisville, KY
    1997 BMW Z3 1.9L 5MT
    On the 4-cyl 1.9, the flange between the TB and the intake manifold has coolant lines, but the heated flange No. 12 is below the TB and would seem to pre-heat the mixture rather than to de-ice the throttle plate. Is not the fuel injected into the manifold well below the throttle and so could not ice the throttle?
    http://www.realoem.com/bmw/enUS/show...diagId=11_1569
    https://www.ecstuning.com/b-genuine-...e/11611247752/
    BMW MOA 696, BMW CCA 1405
    Quote Originally Posted by rf900rkw View Post
    Interesting, that explains why people in cold climates but low humidity don't have the issue either.
    Is there any reason to leave the lines attached in climates where icing is not a concern?
    Feb 2014
    allentown
    Thanks guys.... Considering I just installed the M50 intake swap. I'll do the delete next time I'm in there.
    Oct 2012
    Louisville, KY
    Carb / Throttle icing doesn't happen in "really cold" climates. It takes extreme humidity, which isn't there in sub-zero weather (or Arizona). The typical danger point is 35-45F, but I've had carbs ice on my bikes as high as 50F. Ambient temp has nothing on the sudden temp drop across a closed throttle plate. The one thing that is required is near 100% humidity....
    We don't have carbs, and the fuel is injected into the manifold below the throttle.
    So how does icing occur for a Z3?
    If the coolant lines are for de-icing, where does the moisture come from?
    Or are the lines for warming the intake air? My two early 1970s BMW 2002s had intake air heaters going from their exhaust manifolds up to the big air cleaners.
    Nov 2005
    Finland
    Z3 Coupe individual
    I deleted from mine last summer. The engine side is closed with oilpan bolt and clothes drying rack thingie, either use a U hat pipe like this: https://www.do88.fi/fi/artiklar/sili...0mm-musta.html
    or leave a short piece of hose and put a 10mm bolt at the end of it and ofcourse tighten it with hose clamps.
    It is for warming intake air which is stupid for summer season cars.
    Z3 & E36 RamAir systems, send private message for more information.
    Dec 2007
    Great Dismal Swamp
    Interesting. The coupe, M52TU and M54, doesn't have a throttle heater. At least in this market. Do you have a different engine? Or maybe they did a different intake/throttle for the Tundra edition?
    And before someone jumps in comparing apples and oranges. The electric throttles don't need the heater as much because the conditions that cause icing are avoided in software.
    /.randy
  1. throttle body coolant lines
    By bigmitch117 in forum 1992 - 1999 M3 (E36)
    Last Post: 05-30-2012, 08:43 AM
  2. Throttle Body Coolant Lines
    By mfrisc1 in forum Forced Induction
    Last Post: 07-20-2010, 12:57 PM
  3. Throttle body coolant lines?
    By Windblown79 in forum 1975 - 1983 (E21)
    Last Post: 03-22-2009, 07:28 PM
  4. Throttle body coolant lines
    By jmo69 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 10-10-2008, 02:53 AM
  5. bypassing throttle body coolant lines
    By marc1119 in forum Forced Induction
    Last Post: 01-27-2004, 11:55 AM
