Results 1 to 25 of 30
Thread: Auto trunk lid mod
    IL
    2000 740i sport
    Auto trunk lid mod
    Any try this on an e38 yet? Wonder if it will work on our heavier trunk lids...
    https://youtu.be/1R-FvdUgRuU
    https://www.bearingboys.co.uk/Medium...Spring-31092-p
    Sent from my SM-N960U using Tapatalk
    Dec 2016
    Springfield, VA
    2001 750iL DD74441
    Interesting and good idea.
    They don’t show the closing though. Wonder where it naturally holds on closing and you have to compress it back...
    2001 750iL DD74441
    Stock
    RIP: 2003 540iA Sport GS56111
    H&R front springs, Ultimate Cup Holder, Euro Dash & Armrest, Grom, BavSound Stage1
    Rutland, Vermont
    E30 E38 E46 E85 F150 GTI
    Looks like it would prevent the unwashed from slamming the trunk to close it. That would be a bonus. Couple of valve springs could do the trick.
    2000 740i Sport | 2004 330xi | 1988 325i Vert | 2003 Z4 2.5 | 1995 Ford F150 | 2018 GTI
    Dec 2016
    Springfield, VA
    2001 750iL DD74441
    Eh, for $9 I got a package of 10 springs of the same diameter(s) and compression. Only difference is those are 65mm and the ones I ordered are 64mm. Worth a shot.
    If it works I will have 8 extra...
    2001 750iL DD74441
    Stock
    Jul 2012
    California Inland Empire
    2001 740iL /1991 E32
    Angry Bear keep us posted on how this works. I work at a place we’re your trunk gets inspected before you leave the facility. They have no trunk edicate when closing the boot.
    2001 740iL Guides,chains,vanos done. Full steptronic retrofit,3:15 diff. DUDMD tune. Sport seat retrofit. Porn lights
    [IMG][/IMG]
    Nitto ZR 285/40/18 rear 245/45/18 fr. UUC springs front. Porn lights. Sport wheel
    1991 735iL UUC springs front only Style 42 wheels
    NYC
    99 IL/13 SXT/04 Audi A4
    interested
    El Cid 1999 IL
    DUDMD Tune/DINAN CAI/19 in Style 95 Rims/Bilstein's Shocks/Eibach Lowering Springs/OEM Folding Mirrors/Custom Cupholder/Custom Wood Sunshade/Sport Steering Wheel/Euro Center Console/Leather Shifter/Rearview Camera /Luke Custom 10 in Sub Box/Cross Drilled Rotors/Rear view Camera/BMW OEM Monitors/BMW E38 Picnic Tables/Vanity Headrests/OEM Roof Rack/Strut Bar/Dinan MAF and Dinan Throttle Body and Dinan tunning /BM53 Radio upgrade /Custom Innovadrive NXG39 modify and Alpine ILX-W650 touch screen radio.
    Sep 2017
    Carbondale, CO
    M235, 328dT, 740MSport
    Put me down for a set if they work.
    IL
    2000 740i sport
    Quote Originally Posted by TheAngryBear View Post
    2001 750iL DD74441
    Stock
    Link? I saw some on ebay that were 65mm but the guy who did that e39 recommended 64mm...
    Feb 2015
    Kuna, Idaho
    Too Many Cars (NOT!)
    Gentlemen;
    I (I think) I converted from metric to sae and found this spring domestically. I (think) it's the same. Can someone please verify for me before I jump in the pool and it turns out to be sh**.
    Mike Drives:
    BMW's
    E24 - 635CSiA - (1) 1985 (US)
    E24 - 635CSi - (1) 1985 (EC)
    E31 - 850iA - (1) 1991 (Black)
    E31 - 850iA - (1) 1991 (Calypso Red)
    E32 - 740iA - (1) 1994
    E32 - 750iA - (1) 1990 (Not an "L") (EC German National)
    E32 - 735iL - (2) 1990
    E32 - 750iL - (1) 1990
    E38 - 740iLA - (2) (1) 1997 & (1) 1998
    E38 - 750iLA - (1) 1998
    E38 - 740iA - (1) 2000 "Short Sport"
    E39 - 528iA - (2) - 2000 & (1) 1997
    Also:
    2015 Ram 3500 Dually, Cumins 6.7, Std.Cab. Long box 4x4 (To haul all this junk when necessary)
    2014 Dodge Dart Rallye (Daily Driver)
    2007 Mercedes Benz CL600 (Brabus SV12S)
    Mercedes Benz SL's - (1) (2002) & (1) 1999 500 - (1) 1999 600
    1967 Buick Riviera (2)
    Dec 2016
    Springfield, VA
    2001 750iL DD74441
    Auto trunk lid mod
    Quote Originally Posted by purplecty View Post
    Apparently I got the last Prime order... but others (potentially without free shipping) available.
    https://www.amazon.com/gp/aw/d/B00EKX54PO
    Wow, just looked at that link and it is the item I ordered for $9.74. Now it says the other source is $140? Lol. They heard Bmw owners are buying these...
    2001 750iL DD74441
    Stock
    Dec 2016
    Springfield, VA
    2001 750iL DD74441
    Well the springs arrived and of course I went to put them on to see if this works. Had an old set of lifts and ran into a slight issue.
    To get the springs on you have to pull the caps off. Well they seem like they are on there rather well...
    and simple tools weren’t getting them off.
    So went to eBay and got 2 sets of lifts for $15 (coupons applied) that I think I should be able to pull/screw off.
    Those should be here by Tuesday and I can experiment more then.
    2001 750iL DD74441
    Stock
    IL
    2000 740i sport
    Where did you find 2 sets for $15?
    Dec 2016
    Springfield, VA
    2001 750iL DD74441
    These listings plus I had an eBay coupon for 40% off, so actually $16.50 but close enough.
    https://www.ebay.com/itm/2x-Tailgate...=1933160414008
    https://www.ebay.com/itm/2pcs-Rear-T...=1977334711007
    I am sure these are of the highest quality...
    2001 750iL DD74441
    Stock
    Dec 2016
    Springfield, VA
    2001 750iL DD74441
    Well I have initial results... sort of.
    First, as I suspected the non bmw aren’t crimped like the OE. The ones I got are screw ons.
    So to remove, get your favorite clamp (vice for me) and set on the shaft
    Get a pair of pliers on the head and twist
    Slide on the spring, screw on the head, repeat with the other and all set.
    Now the OD and ID are correct but the length is off between the E39 and E38. While the E39 might be 64mm the E38 is something less.
    Yes the spring is compressed and the trunk is still open.
    Looking back at the old shaft and wear marks I am guessing about 30mm is the goal length when compressed.
    So I might just cut the springs to 50 mm and try. 50mm as the max spring compression is 40% so 30mm divided by 0.6 gives 50mm. (Yes, public math and appreciate any corrections required)
    So more to follow.
    2001 750iL DD74441
    Stock
    IL
    2000 740i sport
    Thanks for doing all the trial and error for the e38...
    May 2012
    1991 850i
    Very useful mod when raining
    Am i the only one liking the factory type opening of the trunk ?
    Dec 2016
    Springfield, VA
    2001 750iL DD74441
    Alright, well I have some results.
    First, the correct length seems to be 50mm. I cut the springs to that length and everything fit and opened and closed. Here are the cut springs
    For those that may be wondering, yes the spring fit internally to the trim piece and yes you have to actively pull it the last 10mm. It doesn’t seem to bind or stress anything so ultimately this mod will work.
    But the bad news: these springs are too weak to duplicate the video. It is enough to slow down the trunk so it doesn’t slam shut but for the opening? Doesn’t do jack.
    When I was looking through the various springs there are many with higher rates. Iirc most don’t give the actual rate but are color coded. Maybe one of the higher rate colors would work.
    For me, here and now, it is nice not to have the “slam” to the closed position past a certain point so I am calling well enough. But for those wanting more, get the higher rate springs and report back.
    2001 750iL DD74441
    Stock
    IL
    2000 740i sport
    Bummer! I figured the e38 trunk is way heavier than the e39 and e46...
    Feb 2019
    Killeen Texas
    00 Bmw 323i
    Factory Opening woirks fine for me
    Quote Originally Posted by pavrom View Post
    I like the small release factory opening...and its because if u ever pop it while in the car by accident....trunk stays closed to the sight and trunk indicator will tell you...I dont need my trunk flying open and wearing out my trunk struts...every prelong savings on my 323i sport is a savings to my wallet.
    IL
    2000 740i sport
    On a side note, how is the quality of those ebay trunk struts?
    Dec 2016
    Springfield, VA
    2001 750iL DD74441
    Quote Originally Posted by Gold Beemer View Post
    Interesting point. The stay close is nice in rain and overall notice. I am not sure it holds that it makes the struts last longer, but I can’t say you are wrong.
    So these are the second link (I think). Besides the screw mounts there isn’t much difference. Honestly can’t tell a difference with action. Time will tell on the longevity.
    2001 750iL DD74441
    Stock
    IL
    2000 740i sport
    But can they hold the trunk lid half way or a quarter of the way open without falling closed??
    Dec 2016
    Springfield, VA
    2001 750iL DD74441
    Yes and especially with the springs in they can hold at lower.
    And yes, I need to clean out the trunk and give a bath.
    2001 750iL DD74441
    Stock
    Feb 2015
    Kuna, Idaho
    So realized after the fact, I forgot links to domestic springs.
    Did more digging after TheAngryBear did the diy and provided a different length. Again, attempting to translate metric/sae. Someone with better translation skills please double check me. Was wondering about the red spring (higher rated "push")?
    Blue spring: https://www.mscdirect.com/product/details/07660582
    Red spring: https://www.mscdirect.com/product/de...61572?fromRR=Y
    Mike Drives:
    BMW's
    Also:
    Dec 2016
    Springfield, VA
    2001 750iL DD74441
    Quote Originally Posted by masbury View Post
    Right concept with the red (185lb) but wrong lengths. The 1” is too short for a single spring, ideally you want to aim for 1.969” (50mm) with deflection to 1.181” (30mm).
    The ID of 10mm (.394”) allows it to sit on the head of the strut. Using 2 1” springs wouldn’t allow full rest on the other leading to binding, scratches, and general bad juju.
    2001 750iL DD74441
    Stock
  1. Trunk lid shock ???'s
    By tlp-96M3/2 in forum 1992 - 1999 M3 (E36)
    Last Post: 08-23-2010, 04:04 PM
  2. Replies: 0
    Last Post: 05-17-2007, 01:52 PM
  3. E36 trunk lid coupe
    By T-Lambo in forum BMW Parts For Sale
    Last Post: 03-03-2002, 06:05 PM
  4. Trunk lid shock ???'s
    By tlp-96M3/2 in forum 1991 - 1999 (E36)
    Last Post: 07-30-2001, 11:23 PM
  5. Euro E36 Trunk Lid
    By TurboBMW3 in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 06-04-2001, 08:27 PM
