Results 1 to 4 of 4
Thread: installation of turner motorsports rear shift linkage bushing
    Jan 2019
    houston
    2017 F150, 97 M3
    I am trying to install this part with the driveshaft removed and am having a very difficult time. I thought I had it installed then when try tried installing the part of the shifter that slides into in, it popped out. I Then tried installing it with the shifter piece already inserted through it and haven't been able to get it back in. The metal around the bushing already has a very slight deformation from trying to get it installed. Does freezing polyurethane to get it to drink have the same effect as rubber bushings? any other tips?
    Jul 2003
    Texas
    1997 M3/4/A
    Is this your daily driver? I would not recommend this for a daily, you will hear every gear loudly. I used a jack and a 2x4 to push it up into place, just make sure the tab and slots line up
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    You really have to push and pry it in. Some don’t like it because they say it adds nvh. I have poly rear console bushings on
    my 99 and 08 M3s and have not noticed that but my cars are modded and have more nvh than stock already.
    Jan 2019
    houston
    2017 F150, 97 M3
    Quote Originally Posted by brokeazz View Post
    I did this today, went right in
    thanks!
  1. Replies: 1
    Last Post: 06-10-2014, 09:03 PM
  2. E36 Turner Motorsport Rear Trailing Arm Bushing Limiter Kit (RTAB Shim Kit) Brand New
    By bladerealm124 in forum Suspensions, Springs & Shocks
    Last Post: 07-22-2013, 11:57 PM
  3. Will the Turner Motorsport E30M3 Shift Linkage Replacement Work?
    By williampeckels in forum 1983 - 1991 (E30)
    Last Post: 07-10-2012, 06:22 AM
  4. E36 Turner Motorsport Rear Trailing Arm Bushing Limiter Kit (RTAB Shim Kit)
    By beteljaws in forum Suspensions, Springs & Shocks
    Last Post: 10-25-2011, 11:54 AM
  5. Turner Motorsports Rear Sub Frame Bushing
    By zerotrip in forum Suspensions, Springs & Shocks
    Last Post: 10-21-2007, 06:41 PM
