Results 1 to 2 of 2
Thread: 750il rear right brake not working
    Nov 2014
    Nevada
    89 750iL 6 Speed
    On my 91 750il the rear passenger side brake does nothing. I do not notice when driving normally as the brake pressure and stopping power feels normal, all other brakes calipers are working. I tried to power bleed it but am unable to get any fluid through. On the ABS module the line labeled HR(right rear) has no fluid coming out either. Any ideas what the cause may be or what tests to try?
    My abs has always felt normal, only reason I discovered this issue is because when stuck in the snow the right rear wheel would continue to spin even when pressed on the brake fully.
    Any help would be greatly appreciated.
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    In section 34 there is some info on the system and testing https://www.bmwtechinfo.com/repair/main/
    with a good tester you can get fault codes.
    Try this, maybe it works:
    ABS/ASC blink codes - Only possible on newer E32/clusters
    German version:
    ABS/ASC-Blink-Code
    - Bremspedal und Schalter "ASC" gleichzeitig drücken
    - Zündung "an"
    - Bremspedal und Schalter loslassen
    - ASC-LEUCHTE fängt an zu blinken
    BC = BlinkCode
    BC 1 = kein Fehler
    BC 2 = EMS Fehler
    BC 3 = Motronic Fehler (DME/ EMU)
    BC 4 = Drehzahlgeber Fehler hinten links
    BC 5 = Drehzahlgeber Fehler hinten rechts
    BC 6 = Drehzahlgeber Fehler vorne rechts
    BC 7 = Drehzahlgeber Fehler vorne links
    BC 8 = ABS-Magnetventil hinten links
    BC 9 = ABS-Magnetventil hinten rechts
    BC10 = ABS-Magnetventil vorne rechts
    BC11 = ABS-Magnetventil vorne links
    BC12 = ASR-Plungenventil Fehler hinten links
    BC13 = ASR-Plungenventil Fehler hinten rechts
    BC14 = Ventilrelais Fehler
    BC15 = Rückförderpumpen Fehler
    BC16 = Speicherladeventil Fehler
    BC17 = Langzeitfehler Druchüberwachung
    BC18 = Leckage Fehler (Wird auch angezeigt wenn Druckspeicher(Gaspatrone) im ASC+T Hydraulikblock schadhaft ist (zB. leer))
    BC19 = Druck Fehler
    BC20 = Getriebebeinflussung Leitungsfehler
    BC21 = ABS/ASR-Regelgeräte Fehler
    BC22 = TD-Signal Fehler (dürfte Tachoimpuls sein)
    BC23 = Option pin Leitungs Fehler
    Zu BC 22:
    TD Signal Fehler
    Regelgerät Kl. 55
    Zündung aus
    Stecker vom ABS/ASR-Regelgerät und Motronic-Steuergerät Bank links abziehen
    Leitung vom ABS/ASR-Regelgerät Kl.55 zum Motronic- Steuerg. Kl.6 auf Unterbrechung/Plus-/und Masseschluß prüfen.
    wenn i.O.
    Fehlerspeicher Motronic auslesen
    wenn i.O.
    ABS/ASR-Regelgerät tauschen
    Translation, hopefully correct:
    - push brake pedal and ASC switch simultaneously
    - Zündung "an" / ignition on
    - Bremspedal und Schalter loslassen /release brake pedal + ASC switch
    - ASC-LEUCHTE fängt an zu blinken/ASC light starts to blink
    BC = BlinkCode
    BC 1 = kein Fehler / no fault
    BC 2 = EMS Fehler / EMS fault
    BC 3 = Motronic Fehler (DME/ EMU)/ DME/EMU fault
    BC 4 = Drehzahlgeber Fehler hinten links/fault speed indicator rear left
    BC 5 = Drehzahlgeber Fehler hinten rechts/fault speed indicator rear right
    BC 6 = Drehzahlgeber Fehler vorne rechts/fault speed sender front right
    BC 7 = Drehzahlgeber Fehler vorne links/fault speed sender front left
    BC 8 = ABS-Magnetventil hinten links/ABS solenoid valve rear left
    BC 9 = ABS-Magnetventil hinten rechts/ABS solenoid valve rear right
    BC10 = ABS-Magnetventil vorne rechts/ABS solenoid valve front right
    BC11 = ABS-Magnetventil vorne links/ABS solenoid valve front left
    BC12 = ASR-Plungenventil Fehler hinten links/fault ASR plunger valve rear left
    BC13 = ASR-Plungenventil Fehler hinten rechts/fault ASR plunger valve rear right
    BC14 = Ventilrelais Fehler/ fault valve relay
    BC15 = Rückförderpumpen Fehler/ fault recycling pump
    BC16 = Speicherladeventil Fehler/fault storage load valve
    BC17 = Langzeitfehler Drucküberwachung/fault long time, pressure control
    leakage fault (is also shown when pressure vessel (gas bomb) in ASC_T hydraulic block is damaged (for example empty))
    BC19 = Druck Fehler/ fault pressure
    BC20 = Getriebebeinflussung Leitungsfehler/fault wire transmission
    BC21 = ABS/ASR-Regelgeräte Fehler/fault ABS/ASR control modules ffaulty
    BC22 = TD-Signal Fehler (dürfte Tachoimpuls sein) TD-signal fault (should be the speed impulse)
    BC23 = Option pin Leitungs Fehler/option pin line fault
    Zu/to BC 22:
    TD Signal Fehler/TD signal fault
    Regelgerät Kl. 55/ control unit terminal 55
    Zündung aus /ignition off
    Stecker vom ABS/ASR-Regelgerät und Motronic-Steuergerät Bank links abziehen/disconnect from the ABS/ASR regulator unit and MOTRONIC module bank left the connectors
    check the line from ABS/ASR regulating unit terminal 55 to MOTRONIC- control module terminal 6 for interruption/plus-/and ground connection
    wenn in Ordnung / in case that is o.k.,....
    Fehlerspeicher Motronic auslesen/read fault codes
    wenn in Ordnung/in case that is o.k.,....
    ABS/ASR-Regelgerät tauschen/change ABS/ASR control unit
  1. E30 1986 es rear brakes not working
    By E30 ga7sh in forum 1983 - 1991 (E30)
    Last Post: 01-14-2015, 11:00 AM
  2. Rear Brakes Not working- need new ABS pump?
    By Wayward in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 08-30-2014, 12:41 PM
  3. Replies: 5
    Last Post: 04-17-2009, 03:34 PM
  4. Rear brakes not working?
    By rchachi in forum 1991 - 1999 (E36)
    Last Post: 01-06-2009, 02:23 AM
  5. Right Rear Door Light Not Working E39
    By BIMMERKILLA in forum 1996 - 2003 (E39)
    Last Post: 01-16-2007, 09:35 AM
