Results 1 to 13 of 13
Thread: BMW E39 M62TUB44 130 TPS control error code, no gas pedal reaction
    Poland
    E36 1JZGTE
    Hello guys
    I've posted that problem in General Mechanical Help but I also would like to try here. I have a problem with my BMW E39 M62TUB44. The engine runs very well except for one thing. You could drive the car for a 200 miles trip and nothing bad happens, drives smoothly as a normal car. However, you just put the gas pedal down to floor (WOT) and immediately (after 1-2 seconds) Engine safe mode program appears. There is no gas pedal reaction then. Engine gets rough idle, bumping from 500 to 1500. You can turn the engine off, start again and works normal again until next WOT. INPA shows only 1 error code - 130 Throttle Valve Position Control . I tried another throttle body, tried deleting adaptations and there is no results. I read that people had problems with thermostat heater plug, but mine is OK, also all 30amp fuses in ebox are ok. Could you point me what to check next?
    Thank you and best regards
    JimLev's Avatar
    Sundance Mesa, NM
    00 540/6, '16 Highlander
    I use to have that same random Engine Failsafe for years. It would happen maybe every 6-9 months, shut the engine off, restart it and it was fine. Then it was happening every 2 weeks, then 2-3 times a day. The CEL was for the pedal pot/throttle body.
    I replaced the pedal pot as well as the throttle body. Didn't fix the problem.
    In a last ditch effort I replaced the connectors and the wiring on the throttle body, the MAF, and the dual temp sensor.
    All of those cables were cracked, didn't see any shorts, and all ohmed out good all the way back to the DME.
    I doubt the MAF or temp sensor had anything to do with it, only replaced those wires cuz they looked bad.
    After replacing the wires 18+ months ago it's been fine.
    Oct 2017
    Beaverton, Oregon, USA
    2001 E39 540i A, 207 k
    Try to clean up your throttle body and throttle electric wires with carb cleaner, and let it dry.
    Nov 2011
    Derby UK
    1999 BMW540 Supercharged
    This exactly the same as I was suffering with a little while ago.
    I changed my MAF and checked wiring, it's not happened in a while but I know it's gonna come back.
    Sent from my SM-G930F using Tapatalk
    1999 540 Auto with Eaton M112 supercharger
    Airlift 3H/P management, M5 steering box, M5 LSD, Eibach/Dinan front and rear anti roll bars, PM Modifich door boards, 4 Eton 6.5s, Sound Magus VS3500.1, 2 x 10" Kove audio subs, Alpine ICS X7 Headunit, 19" BBS Hammer Sports RT245/RT246, Muffler delete, electric coolant fan.
    geargrinder's Avatar
    Mar 2010
    AndoverRockport MA & Intl
    E46M3Cic E39.540iT E84X1
    Quote Originally Posted by Maleckis View Post
    Hello guys
    Definitely nothing related to thermostat.
    It is 99% for sure either 1. the throttle body itself, or, 2. the wiring as Jim says.
    Probably not the pedal itself as that tends to be different error.
    If it reproduce-ably only happens on WOT then I'd have to say almost for sure the TB itself.
    You can try this though: Take the intake tube off, and work the throttle plate back and forth by hand full open/close a number of times (engine off of course!).
    What you're trying to do is scrub away any dust or contamination that is on the internal electronic tracks. Dont bother spraying anything around there its not going to do anything, this isn't about something getting sticky on the mechanical bits.
    Put it back together and see if that fixes it.
    Well actually, put it back together, then clear adaptations, then reset throttle adaptations (no computer action needed - turn key off all the way, then turn key to run without starting and leave it there for about a minute... the throttle then should be adapted) and then​ start it and see if it fixes it.
    If that works, then it probably will be a temporary fix, but very likely eventually it will happen again and sooner or later it will happen more and more until you replace the throttle body. But the hand-movement trick is a good one to know because it will usually get you started if you are stuck on the side of the road with FAILSAFE from the throttle body.
    EDIT: OOPS - I just saw you tried another throttle body. Sorry! Yeah in that case what Jim said. Go over the throttle body wiring with a fine tooth comb. I'm leaving the rest up there because its a useful trick to know about but if you already swapped TB's and the same exact thing happens then its got to be something else.
    2003 M3CicM6 TiAg
    Former:
    1985 MB Euro graymarket 300SL
    Mar 2010
    By the way in the ECU there are parameters for throttle body 'plausibility'... one could edit a tune to make the computer less sensitive to minor throttle body issues.
    Naturally you wouldn't want to blow them away because you don't want the car to go full WOT and through a bunch of pedestrians because it doesn't know what position the throttle is in, but honestly the factory setting is super fussy as we all have found out. It might be something I look into fiddling with. The computer STILL looks at RPM so its not like it can really do that (run down pedestrians on a runaway condition), it'll shut down if the RPM's aren't responding to throttle inputs properly anyway but you could make this "compare track 1 and track 2 in the throttle body and if they aren't the same: FAILSAFE!!!!" routine be just a little more tolerant of some aging and contamination in the TB or the wires...
    2003 M3CicM6 TiAg
    Former:
    Oct 2017
    Quote Originally Posted by Kenny1958 View Post
    Clean up the electric wiring to the throttle body : douse itwith carb cleaner (CRC) to dissolve any gum , then blow it with a hair dryer seton high. Clean up the throttle body plates especially the back of the plates, whileyou are there.
    Then reset the adaptations (engine off, key to position 2,wait 31 seconds, remove key), and test again.
    Mar 2010
    Like I said. It’s not the “gum”. It ain’t a carb with an accelerator pump. You can do that if it makes you feel better. Won’t do sh1t tho. That AIN’T the problem.
    Cleaning the wiring is fine though.
    2003 M3CicM6 TiAg
    Former:
    JimLev's Avatar
    Sundance Mesa, NM
    ^__Yup. Throttle body was changed, ain't that. I doubt anybody in their right mind would put a dirty TB on their engine.
    Wiring is what needs to be looked at, maybe replaced.
    Poland
    E36 1JZGTE
    Of course, the 2nd throttle body was cleaned before assembly. I've replaced the throttle body plug. The plug is completely new now. I've checked all wirings from ECU to throttle body and all of them had 0 ohm of resistance measured from the ECU end to the throttle body plug end. Wires looks good. Do you think that the problem might be caused by the ECU?
    Mar 2010
    Unlikely but not impossible.
    But when you tested wires did you also check resistance to ground for each one?
    And then resistance between individual strands?
    You could get perfect ECU continuity but then find 3 and 4 have some 70ohm connection because there's some bad insulation cracks or whatever.
    2003 M3CicM6 TiAg
    Former:
    JimLev's Avatar
    Sundance Mesa, NM
    Of course, the 2nd throttle body was cleaned before assembly. I've replaced the throttle body plug. The plug is completely new now. I've checked all wirings from ECU to throttle body and all of them had 0 ohm of resistance measured from the ECU end to the throttle body.
    I did all that too, everything checked out good but I was still getting engine Failsafe Program.
    After I changed the wires the problem was gone.
    Mar 2010
    Yep. Like I said - individual wire continuity is only 1 way the wires can go bad... Seen same thing on M5x cars with bad wiring harnesses by the way... harness tests perfect, many parts replaced, yet, only gets fixed magically when the harness is replaced.
    2003 M3CicM6 TiAg
    Former:
  1. Replies: 1
    Last Post: 02-17-2019, 09:29 AM
  2. Brand New BMW E39 FRONT LEFT & RIGHT Control Arms and Bushings Kit
    By simont540 in forum Suspensions, Springs & Shocks
    Last Post: 08-28-2011, 09:08 AM
  3. PLEASE HELPP (BMW 318 2005 E46 dashboard weird error code)
    By mylifeuncutt83 in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 06-13-2011, 04:22 AM
  4. BMW 318 2005 E46 dashboard weird error code
    By mylifeuncutt83 in forum Suspension Tech and Handling sponsored by eBMWParts.com
    Last Post: 06-12-2011, 08:14 AM
  5. E39 535i Manual, year 1996 error codes
    By ptikkala in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 04-26-2011, 03:36 PM
