Results 1 to 2 of 2
Thread: E34 530i swap transmision 5hp18 to 5hp19
    Feb 2019
    Brasil
    E34 530i Touring v8,
    hello friends would like the help of you guys i have an e34 530i Touring and the 5hp18 transmission is skating first and second gear. I have a scrap of one e46 330 2002 she uses 5hp19 I would like to know if she has any way to use 5hp19 on e34. Tnx
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    I have not read about such a swap. In my opinion it will be much easier and cheaper to either repair the 5HP18 or buy a remanufactured one.
    On the E46 the communication system is different, sizes of the transmissions are diffrent, maybe the input and output flanges are different, so maybe you would need a tailor made driveshaft, bell housing dimensions etc.
    The the control modules are different and I am not sure if a TCU of an E46 would work at all in an E34 and communicate with the DME. trans cooling lines will not fit so easy
    Check this:
    Troubleshooting BMW A5S 310Z ZF 5HP18 http://www.bimmerboard.com/forums/posts/1214743/
    here is a 5hp18 valve body overhaul DIY instruction with plenty of pics http://forum.roadfly.com/threads/131...aul-DIY-Part-1
  1. E34 530i m60b30 to b40 swap
    By BimmerBro530 in forum Engine Conversions
    Last Post: 02-26-2013, 02:56 AM
  2. e34 530i s54 swap
    By guitarman36 in forum 1988 - 1996 (E34)
    Last Post: 03-20-2012, 02:46 AM
  3. E34 Differential Swap 530i (MT) to 535i (MT)
    By newbikekiller in forum 1988 - 1996 (E34)
    Last Post: 12-01-2011, 08:10 PM
  4. E34 530i trans swap
    By 530i 95 in forum 1988 - 1996 (E34)
    Last Post: 11-02-2010, 12:24 PM
  5. E34 530i swap M3 engine. S50b32? S52b32?
    By ignitiondelay in forum Engine Conversions
    Last Post: 08-04-2008, 07:26 AM
