Results 1 to 16 of 16
Thread: Quiet Race Exhaust Help
    Sacramento
    1995 BMW M3 Coupe
    Quiet Race Exhaust Help (Update w/Sound Clips)
    My 95 M3 current set up includes schrick cams, intake and headers. Cat delete and UUC exhaust- standard duel pipe set set up. At Laguna Seca I am 95-96 db with down turns away from the sound station. I would like to go to a single pipe 3" exhaust to save weight and get it down to the required 90 db. Anyone have a good formula for a race muffler and or resonator? Thanks!
    NeilM is offline Member BMW E36 M3 Expert
    Fort Wayne, IN
    96 M3, 15 Golf R, 18 Q5
    Maybe it's because single 3" setups are usually configured as full race exhausts anyway, but I've never heard one that wasn't substantially louder than dual pipes. Your UUC exhaust is also known for its loudness. (Years ago I reluctantly returned mine for that reason, and that was with cats.) Resonators with your current setup would help.
    Neil
    joenationwide's Avatar
    joenationwide is offline Makes Cars Dance BMW E36 M3 Expert
    Leesburg, Virginia
    95 M3 (GTS2), 99 M3
    I had a custom 2.5" exhaust on my race car. It had a resonator and a muffler and it was so quiet sounded like a Prius compared to the other race cars.
    So yes get the largest/longest round muffler you can for a resonator, and the largest and longest rear muffler and it will be quiet.
    Jul 2001
    F150, Suburban, M3
    90 dB, not even fun. Last time there, had to run a euro intake filter box, stock cat back exhaust. Open element intake and UCC TSE blew up the meter. Weather conditions will impact dB, and look out for the roving meter... it’s bad enough breathing it out of T5.
    "It's not the people who vote that count, it's the people who count the votes."
    -DNC
    Sacramento
    1995 BMW M3 Coupe
    No kidding and the reason I haven't been back in a couples of years, but it is nice cool place to hit in the summer when temperatures soar and well its Laguna Seca!
    The car has evolved into non-op dedicated track car- this being one of the last bits. I've already frankensteined the exhaust a bit with removing the cats, the twin oem resonators are still in place as well as the cross "X" section. Time to just pull and put in a proper exhaust. As mentioned above a new single 3" pipe with resonator, muffler and a tip that can accept a super trap or baffled down turn is the plan.
    Thanks everyone for your comments.
    Nov 2003
    MA
    Various junk
    Anyone have experience with either a Coast Fab (now PRO-FABrication) or Burns dual stage muffler? I feel like the largest version of these mufflers might be quiet, but I also don't want to experiment with a muffler that costs like $500 just to find out it's still very loud!
    Feb 2009
    Mills River, NC
    95 M3 coupe, 97 M3 sedan
    Quote Originally Posted by GOFASTT View Post
    My setup is similar to yours. '95 with Schrick cams, aFe intake, Supersprint header and a Supersprint catless midpipe that has a fairly large resonator. I have a Stromung catback which I believe is quieter than your UUC. I've passed with the Stromung and also blown 95db with it. Atmospheric conditions play a huge part at Laguna and they can change quickly if fog rolls in. I doubt a 3" single setup would go under 90 without stacking up at least 2-3 mufflers. Hate to say it, but the absolute safest way to stay under 90 for all weather conditions is to remain dual pipe and use a stock muffler section. Intakes can have a big effect too as badmonkey suggested. I used to keep a euro airbox with my spares just in case... but with the stock muffler I never had issues.
    Sacramento
    1995 BMW M3 Coupe
    Thank you for your comments, you could very easily be right but going to give it a go and knowing additional parts may be required. Spoke with Magnaflow and they spec'd (best guess) Rear Muffler – Part # 14149 – 5x8x14” Straight though design – 3.00” Mid-muffler / Resonator – Part # 14419 x2 – 4x14” – 3.00”. Hopefully I will have it installed the next week or so and post a follow up.
    Quote Originally Posted by FredK View Post
    I like the sound clip taken at Thunderhill with a 5dbl drop but agreed expensive for a maybe.
    Sacramento
    1995 BMW M3 Coupe
    Update- final parts installed single 3" straight thru Magnaflow MPE-14419 resonator MPE-14219 muffler. Very happy with the results and sound, but a track day at LS will of course be the test.
    Existing UUC cat back
    Magnaflow Exhaust
    Aug 2012
    Central, MD
    1995 M3
    From the sound tracks, that magnaflow setup sounds good for a straight-through, and noticably quieter than the UUC. But, you added a resonator, correct?
    I may have to look at that magnaflow muffler. I can probably save 10-15lbs compared to my 3" merge to 2x2" stromung.
    Feb 2009
    Mills River, NC
    I like the sound of the Magnaflow. It's difficult to predict on-track decibels from free revving the engine though. Volume goes up a lot under load at full throttle. Be sure to report back with results!
    Sacramento
    1995 BMW M3 Coupe
    Quote Originally Posted by aeronaut View Post
    Correct I added a 4"x16" round muffler/resonator about mid point. Same location as the oem resonators.
    Quote Originally Posted by NoLastName View Post
    Agreed and will do. I attached the muffler tip with a v-band clamp anticipating either the possible addition of a supertrap or a more aggressive 90° tip away from the sound station.
    Fort Wayne, IN
    The UUC sounds just as rorty as I remember. Your custom 3" is much more civilized than expected — impressive!
    Ottawa, ON, Canada
    e90 M3,X5,e46 racer
    We use that Magnaflow on our race cars … they do sound great at full sing! Note that they will get louder as they age … dunno why, guess they lose their packing? Also if you install too close to engine, they can crack/blow out. We had them in the resonator location, but will be moving to rear location.
    Check out the 8legs Racing page: https://www.facebook.com/8legsRacing/
    Sacramento
    1995 BMW M3 Coupe
    Quote Originally Posted by NeilM View Post
    Thanks Neil! I can't wait run this on track
    Sacramento
    1995 BMW M3 Coupe
    Quote Originally Posted by ScotcH View Post
    Blow out? that's wild.. I wonder if your igniting unburnt fuel in the exhaust at throttle lift?
  1. Lil help ID'ing this "race exhaust"
    By doclouns in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 05-10-2011, 08:50 PM
  2. Borla race exhaust
    By Josh///M3 in forum 1992 - 1999 M3 (E36)
    Last Post: 01-25-2002, 12:43 PM
  3. Borla Full Race Exhaust
    By Pika's M3 in forum 1992 - 1999 M3 (E36)
    Last Post: 12-14-2001, 02:22 PM
  4. Borla Race Exhaust System
    By bmwguym3 in forum 1992 - 1999 M3 (E36)
    Last Post: 08-12-2001, 04:00 AM
  5. cheapest, most quiet muffler/exhaust with dtm tips...
    By 94_325is in forum 1991 - 1999 (E36)
    Last Post: 08-03-2001, 05:27 PM
