Results 1 to 2 of 2
Thread: Smoke from back of engine car overhearing
    Feb 2019
    Gernany
    E90 335i E39 523i
    Yesterday I noticed the car was getting quite hot so I popped the hood and there is a hissing noise with smoke caused by coolant protruding from the back of the engine bay in the space between the engine block and the fire wall. So I know I have a coolant leak of some sort. I took it on the lift today and tried to find the leak from every angle but just can’t see it. I’m not really sure what lines run back there but from what I could tell coolant was sprayed everywhere, probably where the smoke was coming from, but I couldn’t see any distinct coolant lines leaking, I don’t even know if I was looking at the right lines. I don’t really want to pay someone to find this leak for me but I already had my mechanic buddy take a glance at it with me. The weird part is today after bleeding the system and refilling lost coolant the car ran fine for a little bit but it started overheating so I pulled over, climbed in the engine bay to look in back, didn’t see anything and by the time I did that the car cooled a little, I drove it back home and it didn’t overheat at all. So basically car is overheating and losing coolant, sometimes. Also could I have a blown head gasket??? Thank you for any help, I’m pretty new to the whole E39 scene. All feedback will be looked into tomorrow.
    May 2013
    Chicago, Illinois
    2000 BMW 528iA
    Sounds like one of the hoses going to the heater core has failed. I believe that they are located under the intake manifold. I would not drive the car until you find and fix this leak. Go to RealOEM and put in the last 7 digits of the VIN and do a search for the cooling system. You should be able to find a diagram.
    https://www.realoem.com/bmw/enUS/select
    2000 528i sport
    EMP Stewart water pump
    Dice iPod adapter
    Alpine amplifiers
    MB Quart speakers
    MTX BGE12 subwoofer
    AudioControl EQL equalizer
  1. Smoking from back of engine bay after VCG and CCV replaced
    By parker90 in forum 1999 - 2006 (E46)
    Last Post: 04-18-2016, 09:04 AM
  2. Replies: 0
    Last Post: 09-30-2012, 12:40 PM
  3. 530d e61 oily smoke from back of engine bay
    By Djreef in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 09-30-2012, 12:34 PM
  4. back left engine compartment smoke!!
    By b5s4convert in forum 1996 - 2003 (E39)
    Last Post: 01-04-2008, 12:07 PM
  5. Got my car back after engine blew
    By Brent_Vino in forum 1992 - 1999 M3 (E36)
    Last Post: 07-26-2002, 07:18 PM
