Results 1 to 7 of 7
Thread: Got the expansion tank out of my 2004 BMW 330xi
    Hanover,PA
    2004 325I
    So I finally got the expansion tank out. When I put in the new tank I had a suspicion something wasn’t seated right. Sure enough when I reconnected everything and poured in some coolant a steady flow came out the bottom. I am thinking the small thermostat below the tank isn’t seated in correctly or the tank isn’t all the way down. How can I tell if the thermostat is seated in correctly? Thanks for any help.
    Jan 2016
    Ca
    2001 525it
    When replacing the plastic expansion tank we replace the plastic mounting plate and hardware since all the plastic is the sam age and brittle and brown. Also use some silicone on the rubber seals so things go together easier.
    MauiM3Mania's Avatar
    Jan 2002
    Central Pacific
    88M3 99M3 04M3 ITBx16
    Moved from the General BMW Discussion sub-forum.
    88M3 AW 43k miles Project FS
    Hanover,PA
    2004 325I
    Hi. I believe I got the thermostat seated in correctly as it clicked. I poured in some water and it is leaking out. I could be wrong but seems like its coming from that smaller tube that comes out next to the wider one that covers the thermostat.
    Hanover,PA
    2004 325I
    Double checked the housing covering the thermostat is dry.
    The coolant level sensor area is dry also. It’s that other tie that’s leaking. On the old expansion tank there was an o ring in there. I am assuming the new one also had that?
    Aug 2009
    Silver Spring, MD
    03M3 17M540 18A5SB
    Not to be funny, but it's seated correctly WHEN IT DON'T LEAK!
    Quote Originally Posted by Shumanfoo View Post
    Sorry again, that's the only way to tell. You might have checked it for leak before ¥ou installed it in the car. So remove the tank and check it out of the car with straight water...
    Feb 2019
    Houston, TX
    2002 BMW 330XI
    I had to replace mine also. It still leaked and turned out to be from the o-rings on my hoses even though they looked fine and felt like they seated when connected. I bought new hoses and my problem went away. Just my $0.02.
  1. 2004 BMW 330xi Coolant Leak
    By gsuhr03 in forum 1999 - 2006 (E46)
    Last Post: 07-09-2011, 07:44 AM
  2. E46 2004 BMW 330xi Premium/Cold Tons of recent maintenance $9600 OBO
    By d3v0 in forum 3 series & Z Series
    Last Post: 01-10-2011, 10:15 PM
  3. Replies: 6
    Last Post: 06-26-2010, 02:37 PM
  4. E46 FOR SALE: 2004 BMW 330xi, 57k, Auto., Cold Weather/Premium, Oregon
    By djohnso6 in forum 3 series & Z Series
    Last Post: 03-31-2010, 04:36 PM
  5. f/s Black 2004 bmw 330xi with warrenty
    By tomstoner06 in forum 3 series & Z Series
    Last Post: 04-06-2009, 01:49 PM
