Hi,
I hope someone could point me in the right direction.
While driving the car made a metal to metal type of noise. My first instinct was to press the clutch and change to neutral. Which was fine. However, on putting it back into gear the car would not accelerate.
So, I had to pull over. On further inspection the car would make a noise when engaged in gear. The noise will get louder the higher up the gears you go. The engine is totally unaffected - the revs stay as they are, and if you press the accelerator no signs of car wanting to go anywhere.
No lights on the dash at the time of the fault.
So, I wonder is the issue with:
1. Clutch
2. Gearbox
3. Transfer Box
I look forward to your help.
