Results 1 to 10 of 10
Thread: 2001 740i ignition key wont turn
    Nov 2003
    Lake Forest, IL
    01 740i,E93 M3,E30 325is
    So I did a lot of searches on this, I am assuming its the tumbler, but all the threads are for earlier cars so I dont know what parts I may need.
    Drove to the office today, car has never had this issue, always starts and shuts off easily.
    Parked the car and then when I came out this afternoon the key wont budge once I put it in. Tried pulling the steering wheel to one side then the other, still wont move, not even an MM.
    I want to get the car home, so I am going to take the ignition switch out and turn with a screw driver, hopefully I can get it started with the Key in the ignition.
    I am assuming I have to replace the tumbler, but what is that part number for an 01?
    IL
    2000 740i sport
    Try some WD40 or lubricant to free it up?
    Sent from my SM-N960U using Tapatalk
    Jan 2016
    Ca
    2001 525it
    Mine started to act up and I replace the tumbler that fixed it
    Nov 2003
    Lake Forest, IL
    That’s the question what’s the part number for the facelift cars tumbler?
    Quote Originally Posted by purplecty View Post
    Nope but I will try today. Left the car last night in the work parking lot.
    IL
    2000 740i sport
    Jiggle it a little too but dont force it...
    Nov 2003
    Lake Forest, IL
    Oh I jiggled it yesterday lol! I will bring the WD 40 with me
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    This is often due to the Bowden cable that runs from the shifter to the lock. Obviously, first check that you have the car in Park as the key will not turn otherwise. If you ARE in Park then re-adjust the Bowden cable using this method:
    https://www.meeknet.co.uk/E38/Steptronic_Adjust.pdf
    My BMW Repair YouTube Channel
    Nov 2003
    Lake Forest, IL
    Thanks that is possibly it, I was able to play with what looks like a circular clip around the ingnition tumbler after I took the covers off and was able to start the car.
    Once I turn it off and take out the key it locks again and wont turn, but all I have to do is turn that clip a little forward with the key and it works.
    That will be my temporary solution until I fix it.
    Nov 2003
    Lake Forest, IL
    Now that I look at it closer it probably is that cable. Is this what its connected too?
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    You can see the Bowden cable in this diagram:
    http://www.realoem.com/bmw/enUS/show...diagId=32_0703
    The bit you have pictured is the transponder ring, barrel and o-ring from right to left....
  1. Ignition key wont turn at all!
    By edognight in forum 1995 - 2001 (E38)
    Last Post: 01-14-2013, 03:11 PM
  2. Key wont turn in ignition
    By Siouxperman in forum 1996 - 2003 (E39)
    Last Post: 09-05-2012, 07:12 PM
  3. Key wont turn in ignition
    By VMZ in forum 1991 - 1999 (E36)
    Last Post: 07-12-2009, 09:21 PM
  4. 90 525i new Ignition Key wont turn to crank
    By VWtechCA in forum 1988 - 1996 (E34)
    Last Post: 11-19-2008, 08:11 AM
  5. key wont turn in ignition [E36 M3]
    By funkmaster in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 07-25-2008, 07:23 PM
