Results 1 to 3 of 3
Thread: psa for chip replacement
    Feb 2016
    Brooklyn, NY
    1995 840Ci, 2013 X5
    My frankenmotor is nearly done. It runs, albeit on 7 cylinders. I think I have a fuel injector issue. I didn't feel like ripping off the fuel rail today, so I decided to change the DME chip instead. Mark D'Silva has exactly the right chip for an M62 running on M60 electronics. Changing a chip should be an easy job, right? Well, it SHOULD be, and after reading this, it will be. The problem I ran into is that there is an uncomfortable amount of force needed to separate the two circuit boards. Wokke's procedure has you prying on the pin side of the DME to release the upper board. After futzing for an hour, I gave up. Timm has an excellent writeup, but I was still stuck at the same place. Instead of prying on the pin side, Timm recommends pushing the opposite side apart until the ribbon cable is nearly straight. Here's the problem with that method--it feels unnatural, downright dangerous. I swore I must have missed a screw or clamp somewhere, or I was in danger of breaking something. Nope. The ribbon cable is stiff and will fight you. Be brave and push that circuit board up. All done in time for tea. Thanks Timm!
    Brett
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    Glad my instructions helped (written over 12 years ago when I had an E32)! Check that each of the injector connectors are correctly mated - it is so easy for them not to seat when re-fitting the overhead wiring trunks....
    My BMW Repair YouTube Channel
    Jun 2012
    Mundelein, IL
    840Ci/6 528iT Europa TCS
    Are you running on 8 now?
  1. #154 DME chip replacement ?
    By royemello in forum 1983 - 1991 (E30)
    Last Post: 01-29-2013, 09:42 AM
  2. Dinan Chip Replacement
    By NWFLBimmer in forum 1991 - 1999 (E36)
    Last Post: 01-15-2010, 08:03 AM
  3. motronic 1.2 dme chip replacement....
    By bhamfal in forum 1988 - 1994 (E32)
    Last Post: 10-14-2007, 10:14 PM
  4. Chip replacement problem
    By Red Herring in forum 1991 - 1999 (E36)
    Last Post: 08-31-2007, 05:57 PM
  5. Do I Need to Replace DME Chip ??
    By singring in forum 1991 - 1999 (E36)
    Last Post: 12-18-2005, 05:30 PM
