Results 1 to 17 of 17
Thread: Quick water pump swap question - 2001 740iL
    Oct 2007
    Bolton, MA
    2001 740iL, 2001 325Ci
    I'm swapping out my current water pump with a new one, (haven't done this before), and not sure of something: There is a pipe (aluminum?) running pretty much horizontally in front of the water pump and ...doesn't look like I can remove the water pump with this pipe in the way. Do I need to remove this pipe (see picture)? What is it?
    Thank you!!!
    Jay
    '01 325Ci Convertible, 5-speed
    '01 740iL, Stahlblau with beige interior & 18" M-Pars, GROM bluetooth
    '03 X5 3.0 six cyl, Gray on gray
    San Jose, CA
    00 750IL, 01 740IL
    You can remove the pipe, but i was able to wiggled it out without the pipe removed.
    Sent from my VS995 using Tapatalk
    Oct 2007
    Bolton, MA
    Quote Originally Posted by asianvenom View Post
    What is it though?
    San Jose, CA
    00 750IL, 01 740IL
    Exhaust recirc pipe
    Apr 2003
    Seal Beach, Ca.
    2003 540s, 2000 740s
    To add to what asianvenom stated, the pipe can be taken off without harming or spilling anything. That does make it easier to R&R the water pump.
    <== Steptronic Sealbeach740
    2000 740i sport: 74k Green/Tan chrome MPars, clear corners, quad brake lights, AIC hi-beams, Hoen fogs, 16x9 screen, MKIV, TFT LCD screen in back, license plate backup camera with "on demand" switch, iPod audio/video (CDC/iPod audio switching, iPod video on 16x9 screen), Basslink, gauge rings, ///M pedals, switched steptronic +/- shifting mode, E46 paddle shifter steering wheel, Dinan engine & tranny software upgrade, DDEs controlled via Euro fog light switch, painted calipers with "BMW" lettering, windows up/sunroof close via remote.
    2003 540i sport: 81k, Sterling grey/grey, MKIV Nav, PDC & CWP - Added license plate backup camera with "on demand" switch, paddle shift steering wheel, windows up/sunroof close via remote, Akebono's, painted calipers with "BMW" lettering, quad brake lights, iPod audio via AUX mode/video via 16x9 screen, BMW TV tuner, ///M pedals & gauge rings.
    Oct 2007
    Bolton, MA
    Thanks all
    Apr 2009
    Land O Lakes, FL
    1986 535i, 2012 X5 50i
    Is actually the secondary air system (injects air the first minute or so when starting cold). It only has two bolts (one at each end) and a clamp i n the center holding it own. You'll need to remove the vacuum hose to the valve and the air injection tube.
    Jimmy Moreno
    BMW CCA 115551
    1986 535i, Arctic Blue
    2012 X5 XDrive 501, Sparkling Bronze Metallic
    Oct 2007
    Bolton, MA
    Quote Originally Posted by jimoreno View Post
    Thank you!
    San Jose, CA
    00 750IL, 01 740IL
    You're right...air injection not exhaust recirc
    Oct 2007
    Bolton, MA
    Got the old water pump off and cleaning everything (removing old gasket remnants, etc.) before installing the new one, but, a couple of questions:
    1. I did not get a new ...plastic flange/washer or o-ring for the outlet tube below the thermostat (see pictures). The ones off the old pump seem okay, but, feels like I should order these and not re-use the old ones, right?
    2. Do people put any grease on the rubber o-rings before putting everything back together?
    Thank you.
    Jay
    Oct 2007
    Bolton, MA
    Quote Originally Posted by jpilk99 View Post
    Thank you.
    Jay
    Just read my Bentley manual and it says to use a "water-based lubricant" for the o-rings. I just don't know what a "water based" lubricant is. White lithium grease.
    Oct 2007
    Bolton, MA
    (Big tangent) The whole reason I took my water pump off is that I'm leaking coolant. I can see it dripping, quite steadily, down by the power steering pump. I can't see where it's coming from, but I ASSUMED it was the water pump. When I took the serpentine drive belt off, I tugged on the fan and there was virtually no play. I guess it's possible that the gasket failed behind the water pump, but, when I took it off, I couldn't really see any signs of coolant leaking out. (Doesn't mean there wasn't, I just didn't see it).
    Now, as I go to put the new water pump on, ...I'm even wondering if that was the problem. With the old one on the bench, I'm pulling on the front of the pump where the fan clutch connects and ...there ain't no play. Does this likely mean the water pump is/was not the source of my leak? Maybe the valley pan?
    I guess there's one way to find out, put it all back together, fill with coolant/bleed system and run the car. Just curious if anyone has any thoughts. Thanks.
    Aug 2018
    Vancouver, B.C.
    2001 BMW 740il
    Valley pan gasket possibly? It fills with coolant and could leak down the front of the engine when nosed down hill
    Feb 2013
    The Motor City
    1997 750 IL
    I think they mean glycerin.
    ---- Processing Individual ----
    Z1XX Upholstery
    Seats front and back in Epingle / leather englishgruen,
    As Schl.Nr. B9EG.
    Front seat backrest in Montana Englishgruen (No. 8 174 861)
    Other interior equipment as for Volleder Nappa englischgruen,
    Schl.Nr. P5EG
    St. Charles, MO, USA
    1996 & 2001 BMW 740il
    I am going through the exact same thing with my 2001 740il. I thought it was the pump, but when I took the old one off it looks and feels like it is in good shape. Put the new one on and hoping it fixes it. I also had to replace the expansion tank. It looked fine but when I took it off it was full of debris. Broken plastic and an o ring fell out. I also had to remove that metal line in front of the water pump. There was no way for mine to come off with out removing it. It was easy though only 2 bolts, the one on the left was hard to see, but easy to pull off and put back on. (As long as the tip of something that you use to line up the hole doesn’t break off in the hole on the left that you can’t see) if this happens it might take about 4 hours of work to try to get that broken piece of something out of the hole. Please don’t ask how I know this.
    Hope that water pump fixes yours, and mine. Good luck
    "Lead by example, follow by choice."
    Jan 2006
    Ft. Lauderdale, FL
    98 740il, 00 540i,04 ZHP
    To answer a few questions...
    Water pumps can fail in a few ways. One is the internal shaft seal leaks. When this happens, the coolant leaks out a weep hole in the bottom of the pump and drips down your engine. Good possibility that is what was happening. The bearing may be fine in this case also, until you run the pump long enough that the coolant gets into the bearing and destroys it.
    The o-rings you have there are probably from inside the coolant hose you hook onto that fitting. The o-ring is part of the hose, not the pump, and I'm not sure if they are sold separately or if you need to get a new hose.
    ***Make sure you get the good BMW water pump gasket (the green one with the black bead on it)!!! The paper ones that come with the pumps suck.
    Nov 2016
    Hansville, wa
    2001 750il Chrome line
    I just did my TCG's and replaced all of the little hose over by the PS pump. That is where I would look for your leak. There are three hoses and a thermostat for the trans oil cooler. Unless I was in there already I would have ignored them. As for the water pump if you can't hear it or see a leak getting thrown around the engine compartment it was probably fine. If you look down past the throttle body you can see a small part of the valley pan and coolant will show up there. If the leak is down by the back of the engine that could also be the valley pan, accumulator, heater hoses or the cover on the back of the block.
    Good luck, be patient and don't throw parts. Find the problem and fix the problem. Enjoy driving your car inbetween service.
    01' 750il Chromeline
    95 M3 LS swapped
    07 M5 Manual
    06' M5, Spartan wheels and a 507hp V10
    00' 740il Dinan, CAI, Romulus exhaust, Stage 5 engine and transmission tune, 750 brakes, camber plates, strut tower brace. Sold
    00' 323i wagon for daughter
    03' 525i wagon for the wife, sold
    98' 740i for the daughter, wrecked
    92' 525i with over 200k, wrecked
    02' R1200 CLC, hit by a bus and broken in half. That one made the news!
    It's like herpes there is no cure but if treated properly you can live with it for the rest of your life
  1. Fuel Pump Swap Question - Will it work???
    By DanAgnew in forum 1983 - 1991 (E30)
    Last Post: 12-11-2009, 12:40 PM
  2. fuel pump swap question?!!?
    By bonecrusher in forum 1991 - 1999 (E36)
    Last Post: 11-17-2004, 02:05 PM
  3. Water Pump Spinoff question
    By Johno in forum 1992 - 1999 M3 (E36)
    Last Post: 06-18-2004, 02:05 AM
  4. E36 Water Pump Selection Question
    By archyx in forum 1991 - 1999 (E36)
    Last Post: 02-25-2004, 01:41 PM
  5. Water Pump removal question
    By errdisable in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 05-29-2003, 08:14 AM
