Results 1 to 2 of 2
Thread: BMW E39 M62TUB44 130 TPS control error code, no gas pedal reaction
    Poland
    E36 1JZGTE
    Hello guys
    I have a problem with my BMW E39 M62TUB44. The engine runs very well except for one thing. You could drive the car for a 200 miles trip and nothing bad happens, drives smoothly as a normal car. However, you just put the gas pedal down to floor (WOT) and immediately (after 1-2 seconds) Engine safe mode program appears. There is no gas pedal reaction then. Engine gets rough idle, bumping from 500 to 1500. You can turn the engine off, start again and works normal again until next WOT. INPA shows only 1 error code - 130 Throttle Valve Position Control . I tried another throttle body, tried deleting adaptations and there is no results. I read that people had problems with thermostat heater plug, but mine is OK, also all 30amp fuses in ebox are ok. Could you point me what to check next?
    Thank you and best regards
    JimLev's Avatar
    Sundance Mesa, NM
    00 540/6, '16 Highlander
  1. Fuel control error codes???
    By flyingvm3 in forum 1991 - 1999 (E36)
    Last Post: 03-27-2012, 06:06 PM
  2. Brand New BMW E39 FRONT LEFT & RIGHT Control Arms and Bushings Kit
    By simont540 in forum Suspensions, Springs & Shocks
    Last Post: 08-28-2011, 09:08 AM
  3. PLEASE HELPP (BMW 318 2005 E46 dashboard weird error code)
    By mylifeuncutt83 in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 06-13-2011, 04:22 AM
  4. BMW 318 2005 E46 dashboard weird error code
    By mylifeuncutt83 in forum Suspension Tech and Handling sponsored by eBMWParts.com
    Last Post: 06-12-2011, 08:14 AM
  5. E39 535i Manual, year 1996 error codes
    By ptikkala in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 04-26-2011, 03:36 PM
