Results 1 to 8 of 8
Thread: Whine/squeal following top end rebuild M70 V12
    Sep 2015
    UK
    1988 BMW 750i
    Hi all,
    Following a top end rebuild on my M70 V12 i've got a weird squeal/whine from the top end. There's a video of it here;
    https://www.youtube.com/watch?v=8Uc6u195k9g
    Any ideas? i can't decide if it's an air leak or more of a dry bearing/metal on metal noise.
    Also one of the injector rails doesn't seat the injectors as low into the inlet manifold as the other. Is this normal? On the one side you can see pretty much all of the plastic ring on the base of the injector whereas on the other side it sits deeper.
    Simon
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    Do you have a mechanics stethoscope? Try with that to find the source of the whine, helped me a lot.
    Just a shot in the dark: maybe the water pump bearing?
    The injector rails are fixed with 2 bolts, total 4 x # 3 http://www.realoem.com/bmw/enUS/show...diagId=13_1387
    if they are in and there is no change in idle when you spray brake cleaner in the area of the fuel injector o-rings, it should be o.k.
    Sep 2015
    UK
    1988 BMW 750i
    H Shogun,
    I do have a stethoscope but the plan has been scuppered by finding out that one of the plastic caps on the injectors has fallen through the inlet manifold and into the engine. I've removed the manifolds but there's no sign off it so i assume it's been eaten by the engine - hopefully as it's light plastic there will be no damage.
    I'll re-assemble paying particular attention to the manifold joints so that should at least rule out any air leaks.
    Simon
    Mar 2013
    Green Bay, WI
    1992 750il / 1991 560 SE
    Thats an odd sound. Did you place the cam caps back onto the exact same locations?
    ______________________________
    1992 750iL
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    If that were an M60 I would immediately say it is the PCV valve (crankcase ventilation valve) - it is certainly worth checking them on the M70 as they can make the same noise.
    My BMW Repair YouTube Channel
    Sep 2015
    UK
    1988 BMW 750i
    I've removed the cam covers and checked the cam caps - thankfully they are all in the correct place. The PCV's were replaced about 3000 miles ago so i'm hoping they're ok.
    What i have noticed though is the poor fit of the intake manifolds to the gaskets. I fitted the gaskets to the manifolds off the car and was surprised at how warped they are - not terrible but enough that they don't sit perfectly flush. Anyway i've gone ahead and re-installed them using Reinzosil in the hope it closes the gap and sorts the noise if it's coming from there.
    Thanks for your help, i'll report back tomorrow night.
    Jul 2015
    Dallas, Texas
    98 750iL, 01 740iL
    that should do it! if not, try a smoke test. next time i do the job, i'll get the max lumens kit
    good luck
    Sep 2015
    UK
    1988 BMW 750i
    Well i can report there has been a dramatic improvement - still a very small bit of noise but so much better. I probably should have been more patient and let the Reinzosil cure for a few days before starting the car but i'm happy at the moment.
    Thanks all for your help, much appreciated.
  1. Check engine light on after top end rebuild.
    By timflowers in forum 1983 - 1991 (E30)
    Last Post: 02-15-2010, 07:51 PM
  2. S52 Top End Rebuild (Machine Shop Needed)
    By loftygoals in forum Texas
    Last Post: 09-15-2009, 09:50 AM
  3. Need help with top end rebuild
    By tally in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 03-15-2008, 04:08 PM
  4. Same problems after top-end rebuild!
    By adamwharding in forum 1983 - 1991 (E30)
    Last Post: 02-05-2007, 11:04 PM
  5. Cost of top-end rebuild
    By infinitenexus in forum 1991 - 1999 (E36)
    Last Post: 09-30-2006, 03:54 PM
