Selling my 2000 BMW M5, color LeMans Blue, 226,000 Miles, 6 Speed Trans. New tires and brake pads. Thrust arm bushings were replaced 2000 Miles ago. Radiator replaced 4000 Miles ago. Car has recently received new plugs, gaskets, Cam Position sensors, Thermostat, Belts, O2 sensors & passenger side fuel pump. New clutch & clutch bearing, drive shaft bearing & Giubo has 1000 miles on it and pulls hard. I had a stainless steel 3" exhaust fabricated that runs from the headers to the rear and sounds great. No dents, never tracked or abused, 2nd owner. First owner was BMW master tech and took meticulous care for this car as I have done.
Sound system if you care: I converted the head unit to double din running an Alpine full size head unit. Alpine amp drives JL audio door & rear speakers. Rockford Fosgate amp drives a pair of Rockford Fosgate 10"s in a tuned custom made box in the rear. Over 900 Watts, system was made for showing at car events and sounds clean.
Full Disclosure:
As you are probably guessing, yes I have removed all of the BMW sound and Navigation equipment. Also, car has the "Secondary Air" carbon buildup in the heads illuminating the CEL. Lastly, the ABS module needs to be repaired or replaced as the trifecta of lights appears on the cluster. Clear coat on the roof needs attention, and there are a few scratches on the rear passenger side bumper.
That said, car runs great I am asking for $5500.00 Or Best Offer!
Last edited by coldproduct; 02-23-2019 at 11:44 AM. Reason: Editing for A Best Offer
Photos?
Pictures added. Updated my location as well, I am located in California.
I like bump
Any questions?
Cell 4242340934, call with any questions about the car.
Car is sold
