I already did a thread a while back, with a no crank/no start. I got a new battery since the old one was low. Car was running fine, left it at work and at night it would not start. Didn't play too much with a low battery, jumped it next day, and nothing.
All lights, electric locks, windows, etc work fine, got a new key from dealer, same thing.
On the 1st key position I don't get the beep beep from ews, or fuel pump priming.
Using a test light I get power to pin 2 (black wire) and out of pin 1 from the ews module going to starter. So I think the ignition switch and key is good.
I am stomped.....
To get to the starter the intake has to be removed?
I don't want to send it to the crusher yet.....
e30 325i, the mighty 4 door granma mobile....Gone
e39 528i, 4 door sports tank
Start reading at post 11.
https://www.bimmerforums.com/forum/s...no-start/page2
Yep. Super low battery could cause the EWS to get scrambled, although normally a new dealer key will usually work.
The best thing to do is to get somebody with INPA to plug in and read codes, and then read 'digital status' on the EWS and try to see this screen:
That screen will show you why EWS doesn't want to run the starter (either key won't be "sending", or, one of the black dots on the bottom will be lit up).
As a general remark, WTF... we have had SO many EWS/no-starts lately its unbelievable. And really unfortunate that most mechanics dont understand how the systems work because there's just such loads of mis-diagnosis and wasted time and money...
2003 M3CicM6 TiAg
Former:
1985 MB Euro graymarket 300SL
Guess it will go to the crusher because I don't know anyone with INPA. Unless I take it to the dealer, but not worth it. Since they would charge more than what an e39 goes for...
sheesh INPA with the cable is only about $30 on the big eauction site, youll need to provide your laptop to run it on.
jim just beat me to it by seconds
I'm going to ask on the nyc subforums, if not I will try and buy it. Unfortunately i live in the boondocks, even repair shops don't want to deal with older cars.
theres an option for a cable with a switch on it, gives you either option, as you may be using it on other BMW's.
All those "K+DCAN etc." cables are roughly the same, though some are better than others.
What that means is, they can work in K-line connection cars (aka E46/39 and older) and also on DCAN connection cars (aka E90 and newer E platforms).
Although F-series cars need yet again another thing as BMW tries to make it harder and harder for techs and owners to fiddle.
You don't have to get one with a switch but honestly its easier way to go.
Once you get it, either run the install from "Mikes Easy BMW Tools" package, or, Bimmergeeks download (free).
You can also buy the Bimmergeeks cable, you're slightly more guaranteed to get a good one that way. OR better, buy it from Bimmerlabs where they tweak the software in the cable to fix some bugs (and a buck or two goes to some of our own forum members). Its more expensive but its slightly better and sometimes the eBay cable quality is up and down from various sellers... with those guys you know youre getting a good one.
2003 M3CicM6 TiAg
Former:
I get a bunch of screens, so i guess it can communicate. Turn ignition on, and use Shift+F8, scroll down e39, engine m52 41.1 with OBD11....
What i don't get is the black dot on the ignition... it's white and off.
Voltage at 12.7.....
If I scroll to body, electronic vehicle imm.. EWS.
I don't know what else....
as i asked in your other post, are you connected with the 20 to 16 pin adapter to the 20 pin underhood port as your car is a 1998? 16 pin underdash connector will only give you DME and trans info (if auto)
https://www.ebay.com/itm/20-Pin-to-O...-/263291156662
Ko-Wreckt.
2003 M3CicM6 TiAg
Former:
So, once you get INPA set up and working correctly on your car, try to follow the steps ins posting #80 and above of this thread. Similar problem, and I think similar solution
https://www.bimmerforums.com/forum/showthread.php?2397348-No-Start-No-error-codes-after-removing-battery-and-charging-it/page4
Yes, absolutely.
That is the preferred way of recharging the battery. Connect the charger to the + and - posts under the hood in the engine bay.
Got the adapter to the car, with the laptop and INPA running. Got couple more screens: engine,transmission, chassis, body, communications.
Go to Body, scroll to EWS, doubke click and get a version do not match and sends me back to menu screen.
Hit F4, read error codes, come up three in german, related to ews. Clear codes, and nothing.
I still don't get a EWS alignment (f2) like on the other posts.
I give up, its been a month, it is like cursed...
