Results 1 to 10 of 10
Thread: Message Chime Glitch
    May 2014
    Springfield OH
    1993 525i 1995 553i
    I am just seeing if anyone else has had this happen. My 93's warning chime for things like "Brake Linings" "Coolant Level" etc did this weird thing twice in 24 hours. Usually on a normal chime it goes "biiiiing" . Well what happend randomly with no new message on the dash was it would do 3 partial bings, so more like "bii bii bii". I feel like something got knocked loose and is causing this or there is some other more serious issue. Anyone had this happen before?
    95 E34 553i6 LS TR6060 Project
    93 E34 525iA Beater with no heater
    VANOS kicked in yo!
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    Black ice warning maybe?
    manual page .....
    Outside temperature warning
    When the displayed temperature sinks to approx. +37F/+3C, a signal sounds and a warning lamp lights up. There is an increased risk of black ice. Black ice can also form at temperatures above +37F/+3C. You should therefore drive carefully on bridges and shaded roads, for example, otherwise there is an increased risk of an accident.
    May 2014
    Springfield OH
    1993 525i 1995 553i
    Quote Originally Posted by shogun View Post
    manual page .....
    Its been well below 37 quite a few times the last 2 months and would do the 1 bing like usual. This morning was warm relatively speaking so no ice warning.
    VANOS kicked in yo!
    Macon, GA
    '94 530iT/A|'95 540iT/6
    Does it still ding like normal for other warnings, in addition to the abnormal behavior?
    Shogun is right about the low temperature warning, but in all of my cars it dings just like it would for any other warning. Nothing different about it.
    May 2014
    Springfield OH
    1993 525i 1995 553i
    Quote Originally Posted by Sir Montalbon View Post
    All the messages are normal dings including the outside temperature.
    VANOS kicked in yo!
    Jan 2005
    Japan
    2 years ago I had a problem with the gong. Came into the garage and the gong was constantly dinging. car was not locked, ignition key not in. Took a drive, ding, ding, ding always. Stopped, key out of ignition, kept dinging.
    Tried the easy things = swopping: cluster changed, gong changed, no improvement, kept dinging, even when I removed the CCM it continued.
    So then I looked into the wiring diagrams and studied them. There are 2 plugs going into the gong, one of them is connected to the OBC, removed that, gong stopped. So I changed the OBC, connected the gong again, problem solved = OBC broken.
    On the German forum I discussed it, they also had similar experience, capacitors had to be changed in the OBC.
    all gong sounds https://www.youtube.com/watch?v=pxnlJAvyr5s
    gong pinout http://www.unofficialbmw.com/john/e36_gong.html
    May 2014
    Springfield OH
    1993 525i 1995 553i
    I will try swapping the one off my 95 see if that fixes it.
    VANOS kicked in yo!
    May 2014
    Springfield OH
    1993 525i 1995 553i
    I think I figured it out. I think there was a setting I turned on the OBC accedentily the rings at the top of the our. When in the time menu, you hit the S/R button and a little icon that looks like a volume icon pops up in the corner.
    VANOS kicked in yo!
    Jan 2005
    Japan
    yes, that is the hourly alarm for radio news, can be switched off.
    Macon, GA
    Ahhh, forgot about that. I accidentally turn mine on sometimes and it throws me off too. Glad you figured it out.
  1. Random chime while driving but no error messages?
    By ObeyPropaganda in forum 1991 - 1999 (E36)
    Last Post: 11-11-2007, 08:49 PM
  2. Can we have like a Instant messaging service?
    By Stylin in forum Forum Software Questions & Suggestions
    Last Post: 06-04-2001, 03:53 AM
  3. Tail light failures - not OBC message
    By Alex '94 325i in forum 1991 - 1999 (E36)
    Last Post: 03-21-2001, 11:51 AM
  4. recent messages from each poster
    By M3 Pete in forum Forum Software Questions & Suggestions
    Last Post: 03-01-2001, 12:35 AM
  5. New Colors for our message board!
    By Bob ///M3 in forum Forum Software Questions & Suggestions
    Last Post: 02-27-2001, 06:14 PM
