Results 1 to 7 of 7
Thread: Door handle: wiring below tumbler?
    May 2015
    U S A
    yay
    Greetings all,
    Does anyone know the purpose of the wiring loom at the bottom of the lock cylinder?
    Swapping in a new handle and my old one is absent this piece.
    Thanks!
    CARS
    02.92 325is / 06.72 2002 / 02.91 XJ / 08.04 R53 JCW
    Peoria, AZ
    03 zhp, 97 e36m3, 04 zhp
    Heated tumbler is one of them I believe.
    Dec 2013
    People's Republic of MD
    22 doors and 4 tops
    3 connections total can be found
    dip switch for power lock/unlock command to all locks and or closing windows/softtop
    heated tumbler
    dip switch that is activated when you pull the handle (this one activates the heated tumbler option)
    You can move the dip switches from one handle to a new one if needed.
    May 2016
    Lexington Park
    99 323Ci, 98328i verts
    Here you go.......
    White is the heater element for the lock cylinder
    Yellow is the door lock cylinder micro-switch
    Grey is the outside door handle micro-switch.
    And that's a brand new door handle that only came with the white, the grey and yellow wiring and switches are from a donor handle that 666 was nice enough to sell me. Be aware that the flange that the plastic connector holder can be broken, letting that sucker hang down and get your connectors all smashed to bits by the window.
    May 2015
    U S A
    yay
    So the only purpose of the grey one is to activate the heated tumbler....
    Thanks fellas.
    CARS
    May 2016
    Lexington Park
    On convertibles, it also activates the slight window drop to allow the window the clear the weatherstripping. Both of my e36s are verts, so I dont know about non verts
    Dec 2013
    22 doors and 4 tops
    Quote Originally Posted by Bill837 View Post
    Bill, to clarify, As XXXXX wondered, the handle dip is only for the heater.
    The window drop sensor is actually in the door jamb. If you stick your finger inside the bear claw catch you will feel and activate the droop.
    Early cars had the window dip switch in the locking mechanism on the door vs the jamb.
  1. Door Handle Wire
    By hajrb in forum 1991 - 1999 (E36)
    Last Post: 07-28-2017, 10:13 AM
  2. Door handle wiring?
    By Talisman850 in forum 8 Series (E31)
    Last Post: 11-21-2012, 07:53 PM
  3. Driver door handle wiring woes
    By 18rabbit in forum 1991 - 1999 (E36)
    Last Post: 09-17-2011, 05:14 PM
  4. E36 WTB: E36 "3-Wire" DS Outside Door Handle
    By BimmerM3inGA in forum BMW Parts Wanted
    Last Post: 11-27-2010, 02:48 AM
  5. Switching tumblers on door handle
    By GoddardCat in forum 1991 - 1999 (E36)
    Last Post: 03-13-2010, 08:14 PM
