Results 1 to 2 of 2
Thread: [E39] How to add to SA new MK3 navi and telephone
    Feb 2019
    EU, Poland
    1997 BMW 520i
    Question [E39] How to add to SA new MK3 navi and telephone
    Hello everyone. In my 1997 520i there was casette radio without MID and any audio-video equipment in trunk. I bought used MK3 navi system with 16:9 monitor, radio, tv and wired telephone and installed it in car. System is working, but few things are not working well because of fact that navi and telephone modules are not added to SA.
    I have been using previously NCS Expert and NCS Dummy to activate/deactivate some functions by MAN file, but I failed to find any solution in Google how to add new equipment to SA. Just found information, that it should be done with NCS Expert. Can someone give me any advices how do it?
    In case of need, I have also BMW SCANNER 1.4 (PA Soft).
    Greetings
    Jun 2018
    Castle Rock CO
    1990 325is, 1998 740i
    I am bored so I am replying to lots of posts today
    When I did my 16:9 swap it was all plug and play except the fact that my car had DSP
    I had to recode my DSP amp to work with the nav so it didnt shut off every few minutes ( google will yield you quick instructions on this) once thats done you're pretty much set
    you could technically rewrite the ZCS of your car to show you have retrofitted the nav ( this year verison of our cars use ZCS not SA)
    I WANNA say ISTA-P also allows you to "retrofit" nav in its module selection area but it doesn't code the DSP amp (at least it didnt for me i had to use NCS to do the DSP amp coding)
  1. E39 E39 525,530,540 Ground Effects, NEW!
    By Sloloco in forum Exterior Lighting & Body Parts
    Last Post: 02-11-2011, 10:11 AM
  2. E39 E39 Rear Passenger Window Regulator & Motor - New from dealer
    By 99FiveFortyMike in forum Exterior Lighting & Body Parts
    Last Post: 10-25-2009, 03:09 PM
  3. E39 FS: 1997-2002 E39 5 Series Service Manual BRAND NEW
    By 01X52Quick in forum Engines, Performance Parts & Software
    Last Post: 02-29-2008, 09:47 PM
  4. E39 e39/e46 OEM bmw water pump NEW
    By B1MMERJ0N in forum Engines, Performance Parts & Software
    Last Post: 02-07-2008, 10:11 PM
  5. E39 FS: E39 540i sway bar links (brand new)
    By NORE in forum Suspensions, Springs & Shocks
    Last Post: 07-17-2007, 11:55 AM
