Results 1 to 3 of 3
    Nov 2018
    Littleton, CO, USA
    2001 BMW X5 4.4i
    Abs / brake warning lights frozen in the 'on' position after airbags inflate
    The instrument panel on my 2001 BMW X5 4.4i was illegible so I remove one from a compatible 2006 X5. The 2006 X5 was in a junk yard and the airbags had inflated. When I installed the 2006 instrument panel, the "ABS/BRAKE and WARNING" logo were all lit up. I had my car diagnosed by 5 different shops and none of them could tell me anything was wrong with my car and there was nothing wrong with my "ABS SYSTEM" None of the shops could deactivate the lights (3) on my instrument panel or reset the ABS warning lights.
    If the air bags inflate, does it render the instrument panel useless? Any ideas or suggestions? Thanx - James
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    moved to X5 forum
    Jan 2016
    Ca
    2001 525it
    Might need programming to the car but I don't know if you can use a cluster from a different car some of the lastest BMW's you can't install a used transmission because there vin specific
  1. ABS / Brake warning lights
    By USNJAGC2010 in forum 1995 - 2001 (E38)
    Last Post: 02-21-2014, 09:28 PM
  2. Replies: 0
    Last Post: 10-23-2011, 01:05 AM
  3. Imtermittent DSC/ABS/BRAKE warning lights when car is cold
    By nutterdog in forum 1996 - 2003 (E39)
    Last Post: 10-14-2010, 12:38 PM
  4. ABS Brake warning light
    By zaneren in forum 1996 - 2003 (E39)
    Last Post: 11-12-2009, 01:31 PM
  5. Phantom DCS/ABS/Brake warning lights
    By grafiksguy in forum 1999 - 2006 (E46)
    Last Post: 05-03-2007, 07:29 PM
