*UPDATE: I modified a E39 jackpad to fit into front subframe, Post 29*
Does anyone know if BMW ever fitted one to the front E36 subframe? Theres a nice hole in the middle for one.
A lot of other cars seem to have them. E46 M3, E46 X drive, E39, E60, E90/E92, etc...
Im thinking of trying the E39 one and hoping it fits or is bigger so then i can drill the subframe hole for it. Has anyone ever explored this topic?
E46 M3
https://www.ecstuning.com/b-genuine-...e/51717894027/
E46 X drive
https://www.ecstuning.com/b-genuine-...h/31101096977/
E39
https://www.ecstuning.com/b-genuine-...d/31111093712/
E60
https://www.ecstuning.com/b-genuine-...t/31112282957/
E90
https://www.ecstuning.com/b-genuine-...h/31116752307/
Everything finished and buttoned up:
I don’t think so? But I’ve seen more than a few people use the subframe anyway.
98 M3 sedan
Uh yes. I'll post a photo of my '98 when I return home. My '92 had one too.
Sent from my Nexus 6 using Tapatalk
Yes you have 2 per side a front and a rear about where the lift holes are. but the pads fall off.
Thus the new design with the locking pin on e46 a rear ( they still fit e36) you just need the jack adapter to work better
do not know why it says 94-94 because in 96 itis a 328?
autopartswarehouse.com
1994-1995 BMW 325i Jack Pad APA/URO Parts BMW Jack Pad
https://www.pelicanparts.com/BMW/tec...Jacking_Up.htm
Thank you gc325is. You nailed it. Not a problem here in AZ, but where there are freezing temps, the river will get hard and shrink.
I'm jealous if you can actually get a jack to your front subframe
But interested for the fun of it.
I’m confused, I jack my car up from the front subframe all the time, why do you need a jack pad to do it?
CBlock
I use a cellulose composite jacking block with the approximate dimensions of 38mm x 90mm.
I need to drive up wood planks or jack one side up to fit a jack to the front subframe.
I bought a new underpanel that covers up the area. Jacking the front subframe would probably destroy or crack the plastic underpanel. I will probably try the E39 jack pad and hope/make it fit. If it does, i can make a cutout in the plastic underpanel for the jack pad.
That makes sense to me now.
For what it's worth, I use two jacks to get my car up. I have the sideskirt extension thing I use and jack up one side enough to slide my big jack under the front. Works slick and I have my car up in the air in just a couple minutes.
CBlock
My OEM Jack (the one that inserts in the Side skirt) twisted on me a few years back due to trying to jack up on an incline. I got home, cut the insert off and welded it to a steel plate i bought from Home Depot and made one of these lol
https://www.pelicanparts.com/More_In...25%20-%20%2450
Works great because and doesn't damage anything since your utilizing factory jack tunnel , and you can be fairly low since the jack doesnt physically go under the car.
I just recently replaced the four round jack pads on each corner but the main reason I jumped on this thread is because I like weird facts about our cars
98 M3 sedan
You can also insert an adapter to the side skirt and gain a few inch in clearance if your car is lowered and not rusted out.
Rocker Jack Pad Adapter
Lift your BMW the way it was designed to be lifted! Avoid damaged rocker panels and unsafe jacking procedures.
Simply the strongest rocker jack pad adapter on the market today!
40.95
I also saw this suggestion, I think the OP wanted ... but there is no pad unlike some newer model BMW.
