hey guys, i bought an e34 525i a while back and today i changed the right blinker and the blinker stayed solid. switched the bulb and as soon as i turned the blinker on i heard a buzz and suddenly the blinker didnt work. (Fuse 6 blew) since then my right rear break light doesn't work and right indicators on front or back don't work either. my left one works just fine. ( and my front right indicator stays solid but it doesnt show on the dash, i also dont hear a clicking from the indicator unless i turn on the left one which works) can somebody help me find out how to fix this asap?
I would look for any exposed wiring, could be shorting out somewhere. Check near the blinker first and its connections since you changed that and then had the fuse blow.
O o
/Ż____________________________ ______________
| BLAAAAAAAAAAAAAAAAAAAHHHHHHHH! !!!!
\_ŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻ ŻŻŻŻŻŻŻŻŻŻŻŻŻŻ
What year and what transmission? I just glanced at the wiring diagrams and the turnsignal circuit is a bit of a can of worms. You could have a failed flasher or crash control module.
The brakelight failure is more ominous. Because it's a completely different circuit, its failure is either coincidental or a sign of melted wiring (BAD. NEWS.).
Got a multimeter and the knowledge of how to use it?
