Results 1 to 9 of 9
Thread: N55 cold start in Canada -42 Celsius
    Jan 2019
    Canada
    f10 535ix
    Does anyone has any idea why that black smoke is comming out ? Only few first seconds
    https://www.youtube.com/watch?v=rsIO...&frags=pl%2Cwn
    Jul 2004
    Houston, TX
    36 Cylinders
    The ecu is enriching the burn mixture to be able to run the engine and warm it up. That is generally normal for that cold of temperatures.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    Jan 2019
    Canada
    f10 535ix
    Thank you
    DE, USA
    '15 435i,'10 535i,'08 X5
    It might be might be normal or it might indicate leaking fuel injectors. Does the engine run smooth or is the idle rough with rpm fluctuating?
    Michigan
    2005 325Xi
    We saw 4 engines (all N55s) seize themselves immediately following the cold snap we had here in MI.
    Quote Originally Posted by B4SH View Post
    If anyone knows, it's this guy who knows literally nothing about everything.
    Quote Originally Posted by fcvapor05 View Post
    Do you even OT? The mean 401k around here is probably about $6, what with all the shiny cars and $1,000 watches and donations to get other members' Volvos running.
    DE, USA
    Quote Originally Posted by Critter7r View Post
    Very interesting.....please elaborate.
    Do engines start then seize after running awhile?
    Do engines fail to crank entirely?
    Do engines refuse to turn over with wrench on crank bolt?
    Michigan
    2005 325Xi
    All of them clattered to a seizing halt within a minute of start-up. Then they couldn't be cranked by the starter or by hand.
    Jul 2004
    Houston, TX
    36 Cylinders
    Justification to keep them in a garage overnight.
    Oil must have been hard jello. What are they putting in these 'synthetic' oils these days?
    -Abel
    Michigan
    2005 325Xi
    None of these cars were outside. :shrug
    If the problem was oil related, I would suspect it was only because the oil had not been changed in quite a while, not because synthetic oils have become somehow inferior "these days".
  1. Runs Rough At Cold Start-Up?
    By Holeshot in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 05-09-2002, 07:38 AM
  2. Rough idle (cold start only) $tealer says...
    By Strapp in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 03-13-2002, 11:55 PM
  3. Loud whine on Cold start ups?
    By Anetsberger in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 03-08-2002, 11:02 AM
  4. Weird Idle problem on a cold start.
    By Austin in forum 1991 - 1999 (E36)
    Last Post: 10-01-2001, 01:23 PM
  5. Cold start question
    By UD///M in forum 1992 - 1999 M3 (E36)
    Last Post: 09-26-2001, 12:48 AM
