Results 1 to 4 of 4
Thread: No fire after starter fix
    Nov 2010
    Navarre, FL
    1991 e31, 1986 e24
    Heya folks...my trusty ole '86 won't start any more after fixing a starter wire issure. Last week the starter wouldn't engage, so I poked around through the relays a bit before I realized I just needed to clean up the starter solenoid wire and stick it back on. I think I messed something else up in the process of fixing the starter wire - now it will crank, but I can't hear the injectors clicking and it doesn't fire. No fuel on the plugs after cranking. I've probably knocked another wire loose or upset a relay...
    Is there an equivalent to the old Bigcoupe "no start guide" floating around? I'm going crosseyed looking at the ETM..
    West Nyack, New York
    86 635csi 98 740i 96 MB
    Feb 2009
    Pittsburgh, PA
    '86 635CSi, '08 128i
    I've had the exact same problem. In my case it was the "start" signal wire. I believe it's a fat black wire with a yellow stripe. It sends a signal to the Motronic from the starter solenoid that you've started the car. Motronic won't start the car without that signal. On many 80s BMWs it's just a spade connection onto the starter solenoid casing, later cars were updated with an eyelet since it has a tendency to fall off the terminal.
    Do you have a copy of the ETM? It's a big help for circuits like this one.
    Save the manuals!
    '08 128i 6MT, '86 635CSi 5MT (B32, Motronic 1.3, WBO2, G265, 18# FW, 3.46 torsen)
    Past projects:
    '96 318iS, sold 4/23 '90 535iM, RIP 1/23 '90 535iA RIP 6/22 '91 318i, sold 7/19 '97 M3 sedan, sold 11/18 '85 735i, RIP 2/18 '92 325iC, sold 7/16 '91 318iS, sold 6/16 '84 745i, sold 10/14 '82 633CSi, traded 9/12 '90 325i, RIP '87 325 sold '89 525i, traded '87 325iS, RIP
    Nov 2010
    Navarre, FL
    1991 e31, 1986 e24
    Weird - I do have an empty terminal at the top of the solenoid, but can't see any wire that would hook up to it. Looks like I have a couple wires going to the hot lead, one trigger wire, and the fat cable to the motor. I do have the ETM.
    Quote Originally Posted by 1986series6 View Post
    Thanks for the link - checking!
  1. Car won't start after LBF fix
    By JPM398 in forum 1992 - 1999 M3 (E36)
    Last Post: 04-12-2009, 09:47 PM
  2. glovebox issue (after ebay fix)
    By jr1966 in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 02-11-2008, 09:05 PM
  3. serious issue after starter replacement
    By Green95Bimmer in forum 1991 - 1999 (E36)
    Last Post: 12-16-2007, 12:42 AM
  4. fuel related no start after starter change
    By 5touringboy in forum 1975 - 1983 (E21)
    Last Post: 12-04-2006, 08:59 AM
  5. AA SC dyno#s after problems fixed
    By b22md in forum Forced Induction
    Last Post: 11-10-2004, 02:19 PM
