Results 1 to 15 of 15
Thread: Instrument cluster lower two aluminum thumb screws.
    Aug 2016
    EastCoast
    2001 740i
    Is it safe to spray some pb blaster on these nuts/screws I can’t get these off.
    Dec 2005
    corpus christi, texas
    No e30s, again :(
    yes but that probably won't help. you are talking about the ones you get to from right above the knee area that hold that plastic trim cover on?
    No e30s again.
    Aug 2016
    EastCoast
    2001 740i
    Quote Originally Posted by superj View Post
    Yes that is correct those bastards are tight
    Joliet,IL
    87 325is 96 GMC Suburban
    I would not use pb blaster inside my car, especially for those that you are kind of spraying at blindly. I’ve had those stuck before also, the ironic thing is that a regular old school pliers with the round jaws gets right at them
    https://www.homedepot.com/p/6-in-Sli...7-49/206829361
    Dec 2005
    No e30s, again :(
    yes, I was going to say just grab them with pliers.
    I don't know why previous owners crank those suckers on when they remove them. it makes them so hard to turn later on
    No e30s again.
    Joliet,IL
    PB blaster is good stuff but damn does it stank
    Aug 2016
    EastCoast
    2001 740i
    Quote Originally Posted by msservices View Post
    You rock will be stoping at the store after work
    Aug 2016
    EastCoast
    2001 740i
    Absolutely have to take the good with the bad the new e30 I just bought was taken well care of
    Joliet,IL
    I just thought of something else...go through your 12 point sockets, standard and metric, and see if any will fit and grab the teeth on those
    Dec 2005
    No e30s, again :(
    those are ultra fine. they seem knurled just for fingers to not slip on them. I don't think anything but pliers would fit
    No e30s again.
    Aug 2016
    EastCoast
    2001 740i
    Got it out perfectly just ordered new gears for the cluster
    Aug 2016
    EastCoast
    2001 740i
    The pliers trick worked perfectly on the LEFT side only due to it having more room to work with the right side I couldn’t get a good grip on I had to lay under the steering wheel head on the carpet lol and use some kitchen liner to get a better grip on the knurled screw
    Nov 2009
    Des Moines, IA
    90 ix, 91 i & ic, 02 325
    Glad you got them off..
    On a side note - I believe those are aluminum so a rust remover / penetrate - prolly wouldn't do too much to help with initial torque..
    Dec 2005
    No e30s, again :(
    they are aluminum, you are right
    No e30s again.
    Aug 2016
    EastCoast
    2001 740i
  1. Removed screws, cannot remove instrument cluster - help please...
    By scoutmasterdave in forum 1992 - 1999 M3 (E36)
    Last Post: 01-09-2005, 10:37 PM
  2. Instrument cluster screwed up
    By thedude in forum 1991 - 1999 (E36)
    Last Post: 06-24-2004, 12:29 PM
  3. 2nd Aluminum instrument cluster surround GB!
    By Bernanke in forum Group Purchases & Supporting Vendor Specials presented by eBay
    Last Post: 01-18-2003, 02:24 PM
  4. FS: Aluminum Instrument Cluster Surround
    By 97 MPWR in forum BMW Parts For Sale
    Last Post: 12-13-2002, 12:27 PM
  5. Aluminum instrument cluster surround GB!
    Last Post: 12-10-2002, 12:52 PM
