Results 1 to 5 of 5
Thread: Strange OBD2 Code - U1408 - Need Help
    Feb 2019
    Cranston, RI
    2014 BMW 328i xDrive
    Hello,
    I have a 2014 328i x Drive, 60K miles. Every since it started getting cold in New England (under 30 degrees) my check engine light has come on with code "U1408". The shop I usually go to thought it was thermostat related issues and it should be under warranty. So, I brought it to the dealer and they replaced the thermostat under warranty, but the same day it was around 15 degrees out and the CEL came back on, this time with U1408 and P0128 (low coolant temp). I brought it back to the dealer, but it was around 50 degrees that day and of course the light was no longer on . They didnt see any fault history related to the thermostat.
    The CEL comes on with U1408 whenever it is cold out (under 30 degrees) and will turn off on warmer days. The oil temperature gauge also doesn't move above 160 when the light is on, and the fans run super loud when its cold out and I have the heat on. Does anyone know what this could be? Car still drives ok, don't seem to be experiencing any power limiting.
    Thanks!
    Feb 2019
    Cranston, RI
    So I accessed the hidden menu in the cluster and after a 30 minute drive (mostly highway at 65mph) the oil temp and coolant temp were only around 90 degrees C (194 F). It was 40 degrees F outside. This seems to be below operating temperature and almost sounds like the thermostat is stuck open, even though it was just replaced. The CEL also shut off again. The oil temp gauge does match what the car is telling me. Any thoughts?
    Jul 2004
    Houston, TX
    36 Cylinders
    What tool are you using to read these codes?
    Basic OBD2 is vague and many times useless at diagnostics. If possible use a scanner that reads BMW manufacturer codes. They will be much more use to diagnosing the car.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    Feb 2019
    Cranston, RI
    Thanks for the reply, I bought a bluetooth scanner and bimmerlink for this very reason. It's coming in today, I'll post back when I scan it.
    May 2019
    New England
    335i F30
    Hi, my car is throwing the exact same codes. What did the bimmerlink say? What was the fix?
  1. FAULT CODE 1264. need help car is sucking
    By CJ7 in forum 1991 - 1999 (E36)
    Last Post: 01-27-2009, 12:11 PM
  2. Code 1216 Need help
    By darkness95m3 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 08-01-2007, 08:02 PM
  3. FAULT CODE 1264, need help please car is sucking
    By CJ7 in forum 1992 - 1999 M3 (E36)
    Last Post: 06-09-2006, 06:12 PM
  4. Code 1216 Need help
    By darkness95m3 in forum 1992 - 1999 M3 (E36)
    Last Post: 08-09-2005, 11:11 PM
  5. Strange cooling system problem, need help!
    By Stylin in forum 1992 - 1999 M3 (E36)
    Last Post: 06-04-2001, 12:21 PM
