Results 1 to 7 of 7
Thread: Water Leak on passenger floor 2008 E65
    Dec 2010
    Corvallis, OR
    97 BMW 740iL
    Does anyone have a definitive fix for this? The roof vents are not leaking, The door seals appear to be valid. This problem seems to be really exacerbated by snow collecting in the windshield wiper well. Are there vents or drains there or do you think this is a problem with the Micro-filter drain?
    Any help would be appreciated. I am ruining the interior on this beautiful E65.
    Thank you in advance.
    Jan 2016
    Ca
    2001 525it
    The vapor barrier under the door panel or the sunroof drains these are the most common, there certern,y would be drains in the compartments along the fire wall get a flashed light and look around check micro filter housings also
    Michigan
    2005 325Xi
    Poorly installed windshields can cause a leak, too.
    Oulu, Finland
    See my sig
    This was right side microfilter drain on my e65. Full of dirt and leaves. Drivers side was clean. It's easy to check so I would do it first.
    Current rides: E65 730dA '04, F10 520dA '11, E34 520iA '91
    Old rides: E46 316Ti, E53 X5, E38 728iA, E39 528iA, E46 318i Touring, E38 730dA, E36 316i, E36 328iA Cabrio, E38 728i, E38 750i, E36/3 320i, E36 318i, E39 530dA Touring, E38 740i, E39 528iA, E34 525iA, E32 750iL, E32 730iL, E34/2 525TDS,
    E34 525i, E28 518i, E34 535i, E34/2 525iA, E30/5 325i, E34 535i, E28 520i https://www.instagram.com/zener__/
    Dec 2010
    Corvallis, OR
    97 BMW 740iL
    All, thanks so much for the help. It is appreciated. This car is too nice to mess up.
    Jun 2015
    New York
    2002 BMW 745i
    Quote Originally Posted by zener View Post
    Did this solve the problem? I’m having the same issue.
    Oulu, Finland
    See my sig
    You just have to check it and clean it from time to time.
  1. Water leak on passenger floor, 2006 325i
    By dhayes09 in forum 2006 - 2012 (E90, E91, E92, E93)
    Last Post: 05-01-2016, 07:38 PM
  2. Water leak in passenger floor ?
    By spcruz in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 11-15-2009, 10:39 PM
  3. Z4 A/C water leak into passenger compartment
    By mjgeronimo in forum 3 series & Z Series
    Last Post: 06-11-2008, 11:19 AM
  4. water leak on passenger side no the floor
    By chopcar in forum 1983 - 1991 (E30)
    Last Post: 05-16-2006, 07:15 PM
  5. Replies: 9
    Last Post: 01-04-2004, 05:46 PM
